andym85 Posted November 19, 2006 Report Posted November 19, 2006 i wired mine like u did in your diagram scratchy...i wired each of my subs to a two ohm load, then ran all 4 wires to the amp, which then parallels them internally to my 1 ohm load... Quote i likes me some audio stuff...
ChevyBoy Posted November 19, 2006 Report Posted November 19, 2006 x2 with my mtx 801d. but that of course was only 2 ohms. Quote
Ernesto Posted November 19, 2006 Report Posted November 19, 2006 Ok, so im almost ready for finals. I wanted to connect my subs to 0.5 ohm today, but came accross a little problem. Ive got 2 dual 2 ohm subs, so I hooked them up to 0.5 ohm. When I wanted to connect them to the amp, I saw that my amp looks to have 2 cahnnels. [glow=red,2,300]I know its not two channels but it still has two +'s and two -'s[/glow] How should I connect the subs? It's made that way to wire it easier.Your going to finals? Quote
scratchy Posted November 19, 2006 Author Report Posted November 19, 2006 ive got it like in all these pics and im seeing 2.5 ohms before rise :V that means less than 800rms, i need more. cant i connect them like at 0.25 ohm and hope to get 0.5? HELP!!!!!! and yes, im going to finals and im really worried because i need to see more power Quote then im rambo bitch
dmanson Posted November 20, 2006 Report Posted November 20, 2006 sounds like a chance you take Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
mrwigglezdj Posted November 20, 2006 Report Posted November 20, 2006 op.. do you have a bad coil? dual 2 ohm sub is 4 ohm or 1 ohm so you should have a .5 ohm or .6-.7 ohm on the meeter between the 2 subs, double check your coils , might have one gone bad Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
scratchy Posted November 20, 2006 Author Report Posted November 20, 2006 not wired bad. I hope to god that I dont have a bad coil. Any way to wire daul 2 down more than 0.5? Quote then im rambo bitch
mrwigglezdj Posted November 20, 2006 Report Posted November 20, 2006 single dual 2 = 4 ohm or 1 ohm 2 dual 2 = 1ohm + 1ohm = .5ohm add one more sub and take it down to .25 ohm only way i know how to drop it more i might be wrong tho Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
scratchy Posted November 20, 2006 Author Report Posted November 20, 2006 shite. Only other subs I have are two dual 4's one of which is burnt solid. I also dont have space to put another sub in my car Quote then im rambo bitch
