subs up in trunk?
sbg
Well you can fit 10lbs intoo a 5lb bag but you gotta have skills. My truck and sensais fusion prove it. 15s in a trunk properly is a tall order though
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I also have a new 2013 kia sportage , but just not at the point to do stuff in it yet. I just picked up 2 hdc3 12s and a saz2500 that I plan on putting in the Kia down the line. For now I am working on this:)
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
How's that expression go...you can't squeeze 10 pounds of shit in a 5 pound bag? Pointing the subs at the trunk lid has many cons, one of which is excessive rattling. Going to cause you to lose a lot of the pressure that you'd otherwise have. How much airspace a piece do those 15s call for in a ported application?
I have 3-12s in this trunk now and it has flex and what not but it don't rattle much at all.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
So what I am going to do is pull 6x8 out of back deck. Gives me 2" more on the height so now I can go subs to side and port to front. I know this setup will work well in this trunk. Because I have ran setups like this in it. Looking at around 7ft^3 now, still not as big as I would like but will work. Just going to suck having to build it in the trunk lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
so I just got 2 soundqubed SDC 2.5 15s. and need to make them work in my trunk of my car. think the only way I can make a box work for them is subs up, and was not to sure on if it will work out. working with 14' H 32" w 35'' D . looks like I can get around 5ft^3 with that. what u all think about subs up and port to front?
u can do aero ports through your rear deck
Well I started today. If I don't work out then I will burn this bitc* down lol.
EE591C44-3FFB-4784-8187-38C2632CDE54-789
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Off AQ's site, but since you already have them then there really isn't much you can do.
Remember, SoundQubed subs use the same motors and have the same excursion capability for a given series. The system output and bass extension will have the same potential regardless of sub size. The key to a loud system is to make the most out of the available space. Larger diameter subs squeezed into a small box volume will not be as loud or deep as a smaller diameter sub in the ideal volume.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
I know, I got them 2nd hand real cheap so I am just making it work. Should still be loud
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
