Looking for door ideas need help
Trying to figure out what to do with my doors. I wants some 8" mids and possibly some 6 1/2s too any ideas? Single Cab Ford Ranger with bucket seats. Heres a pic of door panel
94 Ranger Std. Cab Bagged and Bodied
Audio under construction:
Center Console Ported Wall
4x SA-8 D2
Soundqubed 2200d.1 @ 1Ohm
Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721
2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro
4x Fosgate Punch 300.1
Big 3 Upgrade Kandywirez
XS D3400
09 Lancer Turbo
1- 12" DD 512B
SoundStream Rub1000.1 (turned way way down)
Avix-930bt
If I were you, I would pick up some PAs (crescendos possibly) and try your hand at fiberglassing. No better way to learn than to dive it
Ive done some glassing before, what kind of layout do you think i should go with? I worried about clearing the seat when i shut the door.
Thanks
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
tuned in I am looking for the same thing for my car ut my door panel layout is crap to work with
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
If you cut out where that pocket sticks out, should give you plenty of room to glass the 8s and 6.5's without having to worry about depth and clearance, right ?
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Get some tupperware bowls (about the size of speaker you want) and tape them to the door. Try different spots and whatnot, and if they close without hitting the seat, you're good!
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
It will be cut out forsure just honestly would like to fit 4-8s in each door but idk
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
danm good idea lol sounds funny but it would work
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
I'm still in the process of working on a fiberglass door for my Cav with bucket seats. Decided to do an entire door panel rather than pods so I cut the door shape into a half inch thick piece of birch, and went from there. Cut out my flush mount rings, bolted the birch do my actual car door with the plastic panel off and held the rings up with the speaker I was using in them to make sure that I had enough clearance. Had to move around the design a few times before I cleared the seat but I managed to fit 4 6.5 PWXs :)
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
