Wiring 20 subs
Geeze, 20 off of 1 amp is gonna be a huge headache. performance may not be the best either.
But if you had D2 woofer, you can parallel each for 1ohm each woofer
Then series 5 woofers together and have 4 groups of 5 at 5ohms each.
Then parallel the 4 groups together for a final load of 1.25 ohms nominal.
Of course with all those woofers and series wiring, you will rise up very high and efficiency will fall.
Any reason you would not want more amps?
Yep Huge Headache! Also if one coil goes out on one of those subs there goes an entire group that doesn't play.
so it would better to 5 amps, opposed to 1. Will do. Thanks guys.
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
Take a pair of drivers and figure impedance how you need it. Then divide by 10.
2 ohm pairs become .2 final load.
8 ohm pairs become .8 final load.
16 ohm pairs become 1.6 final load.
And yes, worst case is an open coil costing you a pair of drivers.
As mentioned best to use multiple amps on fewer coils each.
Static drops are my bag.
Yes it would. With that many woofers, the more amps the better.
Youd want to try and avoid wiring multiple woofers in series as much as possible. Just to make it easier on troubleshooting and setup, and increase reliability of the system.
If you did use 1 amp and a voice coil on 1 woofer went out, you may have to spend a day tracking down the issue. With 5 amps or more, you can certainly make such a job far easier. And it will also run more efficient and you can get more power.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
I would do 5 amps instead for sure. Then do 4 per amp with D2's series/parallel for 1ohm load per amp, or 0.5 per amp with D4's in parallel. (More Risk with the D4's) But after watching Mr. Lester's vid's more efficient due to wiring method.
Thats what I'm doing, already put order in for subs.
Thanks
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
8-XS Power D3100
Subwoofers
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
