how far does port need to be from trunk
It is a 6" port..
What else do you want us to say?
Your options:
--Find the leaks (take off ALL your panels around the trunk area from the cabin, shine a bright ass light in the trunk towards the deck(when your box is in) and look for light from all different angles through nooks and crannies)
--Leave it as it is.
--Turn the thing around and hope that it doesn't choke the it out. You aren't going to know this unless you try.
--Push it back to the back of the trunk (assuming everything is forward, (port and subs))
--Build a new box and fire it rear.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
He solved this. Via some looking and stuff I got a picture of the leak. It was in his rear deck, a huge hole on each side up near the rear window area. I guess he assumed the rear deck was solid near the seat back that it would be all the way through.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   1 Member, 0 Anonymous, 3383 Guests (See full list)
