Trayten Posted October 24, 2013 Report Posted October 24, 2013 Ok guys, a very bland question so go ahead and list anything, but I'm wondering, what's next? I've got my head unit, my sub, 2 amps, and box built last weekend. Where should I go from here in terms of buying more stuff for my system? Another battery or new alternator are in the picture, but I don't really know what else I need from here. Me being new at this stuff I always just knew the big picture lol. Fuses and fuse holders (would I need 2 for 2 amps?) 0 gauge ofc? what else is necessary? also, anyone give me an estimate of how many feet i'll need of wire? For 2 amps in a pretty long car, what's a good number of feet to go with? Thank you! Vehicle: 1988 Cadillac Brougham Pioneer DEH-X9500BHS Head Unit Custom box built by me (designed by forum member g2shuck) (1) DC XL 15 (2) SQ q1-1200d (2) Crescendo PWX-6's. (more to come someday.)
john253a Posted October 24, 2013 Report Posted October 24, 2013 No one can answer that The only answer we can give Is use the right fuse to suit the wire size How many runs Alt and other things we can only answer if you tell us what u have
Trayten Posted October 24, 2013 Author Report Posted October 24, 2013 No one can answer that The only answer we can give Is use the right fuse to suit the wire size How many runs Alt and other things we can only answer if you tell us what u have Nobody can answer what is typically needed for my system? That sounds outrageous.. if you're talking about my car, its a 1988 cadillac. I'm not sure how many runs cause I've never installed subs or amps before so I have no idea. What fuse size would I use for 1/0 gauge ofc? Vehicle: 1988 Cadillac Brougham Pioneer DEH-X9500BHS Head Unit Custom box built by me (designed by forum member g2shuck) (1) DC XL 15 (2) SQ q1-1200d (2) Crescendo PWX-6's. (more to come someday.)
g2shuck Posted October 24, 2013 Report Posted October 24, 2013 shoot me a text man ill get you set up 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
john253a Posted October 24, 2013 Report Posted October 24, 2013 what equipment do you have already, if nothing then say nothing, if just a head unit then say that, i like to use 0g cable but you may not need it for your system
g2shuck Posted October 24, 2013 Report Posted October 24, 2013 His stubstage is a dc xl 15 ina porperly built and tuned ported box ran off a pair of strapped aq1200s. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
kl0wn Posted October 24, 2013 Report Posted October 24, 2013 Well, the AQ1200's accepts 4 gauge, not 1/0. So if you plan on putting that 1/0 into the amp you will need reducers. Instead of using reducers, you could add a battery to the rear, have a run or 2 of 1/0 from front to back, then the 4 gauge coming off of the rear battery to the amplifiers. Fuses for 1/0 wire are normally 300A ANL Fuses. For 4 Gauge I generally use a 125 or 150A ANL Fuse. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
sayhuh? Posted October 24, 2013 Report Posted October 24, 2013 what equipment do you have already, if nothing then say nothing, if just a head unit then say that, i like to use 0g cable but you may not need it for your system Learn to read. Sheesh. Like Klown said.. just an example...for the distro block before the amps. Then you can 4 ga from that. http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12 you're on the right track. How many feet of 0 ga you need, I don't know. That is a LONG car. You'll want in line fuse for sure also. RCAs? Remote wire? Blown
g2shuck Posted October 24, 2013 Report Posted October 24, 2013 Do a run of sky high 1/0 from front battery back to the amps then use a toolmaker 1/0 to dual 4 gauge block to power the amps. Put a 300 amp fuse on the 1/0 cable at the positive battery post to fuse the 1/0 wire then put a 125 amp fuse on each 4 gauge wire at the outputs of the distribution block to fuse the 4 gauge wires. You do not need to worry about amp fusing since the aq1200s have built in fuses. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member
White Lightning Posted October 24, 2013 Report Posted October 24, 2013 How bout a good sound stage setup to make it an all around audio system instead of just distorting bass ... just saying ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
