bigmizzle99 Posted October 30, 2013 Report Posted October 30, 2013 I have a '13 Altima 3.5SL with the Blose system. Its a lease. I'm planning to add some beat to it but in stages and in a way that I don't ruin the stock system in case I decide to give it back (I could keep it after lease). I will need to tap the main OEM wiring harness (while keeping the molex connector intact) to get to the primary Front/Rear L/R sources for the Blose amp that is in the trunk. Which method of tapping the signal would anyone suggest? 1. I could cut the wire and *try* to solder an additional wire into it. I may have issues with working space in the trunk to do this. 2. I could try to remove these 8 wires from the molex harness and then try the solder route. 3. I could use one the many aftermarket "Tee" connectors and just crimp onto the wire to route the signal over to new sub amp. Which do you suggest? Camaro SS Build Altima build 2.0 Altima build 1.0
Tarball Posted October 30, 2013 Report Posted October 30, 2013 Lease - tap in the rear with scotch lock connectors to LOC. Add mild system and big 3. Remove system And big 3 at end of lease. If you keep the ride, expand like a mofo. 3 CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
bigmizzle99 Posted October 30, 2013 Author Report Posted October 30, 2013 I've been reading and planning for a while, here are some ideas. I like what I've seen/read about the SA8s and I was impressed by pricing and Steve's amp test Tuesday of the DC 1.2K. Camaro SS Build Altima build 2.0 Altima build 1.0
ham4864 Posted October 30, 2013 Report Posted October 30, 2013 know matter what i do i still try to solider my connections. 2009 bmw 5 series Head Unit Stock Amplifier-JL Audio JX 360/4 Processor- Audiocontrol LC6
Rmichael91 Posted October 30, 2013 Report Posted October 30, 2013 Don't use t-taps I beg you. I've used crimp caps with installs, If they ever wanted something different swapped in or added I just opened up the crimp cap and used a new one with the wiring. Simple and secure.
bigmizzle99 Posted October 31, 2013 Author Report Posted October 31, 2013 Do you have a link for crimp caps? Camaro SS Build Altima build 2.0 Altima build 1.0
bigmizzle99 Posted October 31, 2013 Author Report Posted October 31, 2013 Never mind I googled. Don't think I want to use those, however. If I cut the wires then I'd just use those self solder butt splice connectors instead. Camaro SS Build Altima build 2.0 Altima build 1.0
