DC Sound Lab
I have 48 width x 40 height x 36 depth to work with which is actually 34.39 gross with 1 inch mdf if my calculations are correct. Of course I would not be using 1 inch. Is will be 1.5 inch walls and port with 3 inch baffle. Not trying to sound like an ass hope I am not that is the actual measurements I have to work with if I build it in the car.
Edited by g2shuck
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
A lot if the car has already been cut out for my current trunk build is why I have so much room I forgot to mention that lol
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
I would.honestly remeasure.36 inches is 3 feet. My wall taking up my entire rear portion of my extended cab truck isnt that deep. It just seems like your measurements are off. Id build a base first and then work off the base. From there you can see just how much space you have.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If I combine the two ideas above of weight saving with two 18s and Cody suggestion of a 10k I could to two level 6 18s on a 10k and only need 12 cubes net
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Whihc is more realistic in a car.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Any idea what realistic tuning for a level 6 is? I can't get winisd to work on my new laptop for some reason
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Not a normal lol camry most the rear interior metal has been removed :-)
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
I probably have roughly 12 inches more depth and 12 inches more widths to work with than a stock camry
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
