Soccerballzs Posted November 6, 2013 Report Posted November 6, 2013 Could be your gains are set to high. Turn them down to below 1/2 and see if it stops. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Mikey Bates Posted November 6, 2013 Author Report Posted November 6, 2013 Could be your gains are set to high. Turn them down to below 1/2 and see if it stops. Gains will be set this weekend with DD1 -5 DB. Could be it also but doubt it
BigManAC Posted November 6, 2013 Report Posted November 6, 2013 Did you switch them at both ends? the amp and the Deck? or only at one end? as in the L on deck RCA goes to R on amp and vice vs. ? thanks for you input I just switched it on one end. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
BoomZoom808 Posted November 6, 2013 Report Posted November 6, 2013 I had this issue and the way I was able to resolve it was to bypass the ground wire in the factory wiring harness and ground the head unit directly to the frame sanded down to bare metal. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
finkster Posted November 6, 2013 Report Posted November 6, 2013 I just made a thread that is stickied in the head unit section of the forum. That should get you on the right track. good luck. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
