Power wire short? (worked and now doesn't)
All my wire is Knuconceps. 0 gauge, 4 gauge, RCA's, the lot.
recently my 4 gauge run seeming lost its ability to transfer current. One day the amp worked fine, the next there was no turn on, no led and the voltmeter showed that the 4 gauge ground was fine but that the positive from the battery was not reading. the run of 0 gauge is fine (ran the same way in roughly the same spot.
I thought my amp had fried at first.
The fuse does not look blown to me, though it is the cheapest little fuse holder knuconcepz makes and its honestly a little hard to tell.
Im not even sure you can replace the kind of fuse thats inside the fuse holder as it does not come apart and it is a little lightningbolt shaped fuse that i have never seen before
I believe it is an 80 amp fuse and the amp wants 100 amp.
So is my wire shorting out somewhere along the run into the chassis? what is going on?
Thanks for checkin it out
sam
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
bump
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
You probably have a bad fuse check it with a meter. Before fuse and after. Put 100 amp fuse if that is what amp needs.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Did you test the fuse holder with a dmm for continuity?
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
I've never heard of a fuse holder that doesn't come apart much less from a good company like knu.
The knu fuse holders suck
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Never, ever, ever check a fuse visually and think you've checked it. Fuses sometimes look blown but often, they're blown and you cannot see that they're blown.
Always check the fuse with a meter, a continuity tester or a test light.
Until you've tested the fuse properly, there is nothing else to discuss.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
fuse is not blown.
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
