Bump4life's SuperCapacitor Overview and Testing
I use to have blacks an used them with blues .. When I bought blacks in eBay few years back I had 9 out if 12 bad they leaked or didn't charge .. I was always weary of hooking in series to amps because of this .. The way I did it was one pos from batt to amp dual input the other from cap bank to dual input .. Had some amp failures wasn't sure why but found two bad caps on my banks .. Question should grounds come from battery or frame .. I know there's a lot of current going through wires .. How many banks of blues for 20 k I have 4 now which helps with battery's but I know I need more just no room
i would say its worth every penny to buy new that way you know they were not abused or are bad. I will never buy the black ones off people. The blue ones i would if they were a trusted source.
for 20k i would have at least 12 banks maybe more? I'm going to have 8 banks on 10k. And im running 3 banks on 5k and a stock alt and hold great voltage.
i would have 16 banks for 20k at a minimum if you want to hold voltage. esapecially if you are wiring lower than 1. the number of alternators also comes into play.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Why can't you charge to 17.0 with 6 blues? 2.7 x 6 is 16.2 and 2.8 x 6 is 16.8 so .2 more volt is not gonna hurt a thing.
you can charge to whatever you want. the banks with 6 in series are rated to 16.2 MAX. with a surge rating of up to 17.1. personally i dont like to push things and break down the innards. will they take it for a burp or 2. sure. but i sure as hell wouldnt be driving around daily pushing 16.2 volts or more. thats asking for failure.
BMW M340 xDrive
If they are balanced is key but meh don't be scared :)
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
yea balancing is key, but i guess i dont like to push things past their rating for my peace of mind. I am sure they will do it for perieods, but my car shuts off at 16 volts, plus i dont drop any. but by all means if people equipment allows for a higher voltage use at own risk!
BMW M340 xDrive
updated with charging and size, new vs old.
if you have any suggestions or if anything is unclear leave a post!!
i have a charger that charges at 14.06v could i use it to introduce a charge i believe it has a 5 amp and 2.5 amp setting
these are the ones i ordered
http://www.ebay.com/itm/251472523845?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
any battery charger or power supply would be fine to charge the caps. They key is the resistive circuit. You need the resistors other wise your charger will go into its short protect mode, or if you dont have short protect then it will break. and youll be buying a new charger.
the ones you ordered are good. for 30 dollars more you can get new ones though... those ebay ones are used as you can see in the description
those balancing circuits are active. they will do nothing in most peoples systems especially if using the blue caps. once i add the balancing section it will be clearer
crap didn't realize they were used fml -.-
skar sk2500.1
alpine HU
vxi65 components on BA gt-275
2 x-15 sundowns
so i confirmed something today about the boost caps. if your capacitors say boost cap they are last years model. i believe from 2012 to early 2013.
on them it says patent pending. on the new blue caps it only says maxwell. My guess would be they got the patent approved. Thus is you have the boost caps they are still authentic maxwell. just all of them if bought will be used, so if someone is trying to sell you them for a new price id call them out.
BMW M340 xDrive
So is there any interest for another group buy? I'm sure there's a bunch of people that want caps after reading this thread
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I'd be interested depending on price and when it happened.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
i have plenty of caps left after my 500 cap purchase (i have 300 left, sold 200 already) if people are interested enough I could set up a vendor account on here to make it legitimate and be able to advertise and sell
i can also design full banks as well for any size power.
sorry if this post is pushing it. this thread was created for informational purposes. lets get back on track.
If anyone wants to be part of a group buy, please refer to the group buy thread located in the group buy section of this forum near the bottom. lets keep this thread information and Q & A.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 525 Guests (See full list)
