BassMunky Posted November 7, 2013 Report Posted November 7, 2013 what would be or what can fit in my scion xb 2013? what would sound good and I want to be loud Subs in the back with the seat up no wall, 1- 18 2-15 2-12 or any other ideals? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Crandis16 Posted November 7, 2013 Report Posted November 7, 2013 Post dimensions out of the 3 that you posted 2 15s will be the most cone area. Give up dimensions and we can tell... I have not actually seen what the trunk of an xb is like My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
CleanSierra Posted November 7, 2013 Report Posted November 7, 2013 2 12s. I had a 2008 which I'm sure is the same cargo area as yours 2 15s are too tight of a fit and won't leave any room for your port to breathe. You can do subs up/port up and you'd have to build the enclosure with an angle to follow the seat line, but you could MAYBE squeeze a couple of 15s in there. Dimensions should be about 40" wide until you hit trim panels, 18" height without going up to headrests(right at top of seat line) Depth is variable depending on how you want to do it. A totally squared off 90° enclosure can maybe get 18" depth but port would have to face up. You can get deeper if you follow the angle of the seats though. Go measure and see what dimensions you get. See what dimensions you don't mind giving up. Im not the one you want to try to troll. Just a fyi for you.
ric006 Posted November 7, 2013 Report Posted November 7, 2013 2 12s like clean said you can go Subs up and port up or Subs up and port back
Jd1102 Posted November 7, 2013 Report Posted November 7, 2013 2 15s subs up port up glass the bottom and sides for the airspace
BassMunky Posted November 10, 2013 Author Report Posted November 10, 2013 Well I want to be able to remove it if I have too. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
slowfkncar Posted November 10, 2013 Report Posted November 10, 2013 The older xb can get away with a larger enclosure because of more height. The newer xb you will have a hell of a time with two 15"s unless your planning on having the rear window obstructed. I would do two 12's . I have done 2 15 sa15's and they had a hard time getting low in a 2011 xb. Not to mention you could not see out the rear window and the sub & port only had something like 7-8" away from the roof. Yes the roof flexxed like crazy and that 33hz box was louder around 38hz probably because of the port so close to the roof.
BassMunky Posted December 1, 2013 Author Report Posted December 1, 2013 gotta measure anyone on here with a second gen scion xb build? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 8, 2013 Author Report Posted December 8, 2013 second gen peeps Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 11, 2013 Author Report Posted December 11, 2013 any other build or advicw Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
