Calculating port area with xmax?
shanesauce
Just to make sure - the formulas use Vd. That is the peak to peak swept volume, not one way Xmax.
I think your minimum calculates to 55 sqin, unless I misunderstood something.
In a car, you don't really have to have that much. The port may not operate 100% correctly at maximum driver excursion, but it will work.
Yes, an aero can have less port area. It eliminates a significant amount of port noise. Once again, the port may not operate 100% correctly, but as long as you don't get so small that the system begins to act like a leaky sealed box instead of a ported box, it will be fine.
I would guess ~30-35 sqin is enough for that pair of subs. Or you might could get decent results with one 4" aero.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I just typed in the xmax from the website and the amount of drivers and desired tuning and that is what the calculator gave me.
I am honestly just thinking about running external aero's, I didn't want to do it before but it just seems like the smartest thing to do...
In terms of aero it is giving me 6 inches of aero diameter minimum so (2) 3" aero's at 11" long each will give me 32hz and should yield no port noise.
Am I doing this right? I am so tired of trying to get this right lol
- 2012 Mustang 3.7 Manual
- Audio under construction
Okay this is my final idea just let me know if it sounds good.
Build a 1.4 gross sealed box, cut out for (2) 3" aero's at 11 inches in length each giving me a tuning of 32hz.
This gives me 18.84 inches of port area or 6 inches in diameter of port which is optimal according to the calculator.
Sound good? I am ready to build this thing once and for all. Port external not internal
Man 1 6" port is about 28 square inches in area 2 3" adds up to 14.1 square inches, don's see what vehicle you are working with or dimensions for a box, power you are using? 2 4" ports have almost the same area as a 6" not two 3", ports in small boxes tend to be very long so slot ports which can turn easily are a likely a better choice. If those are sa-8v2 and you use two 3" you are likely to experience port noise or at least loss of output at the power levels those can take (750+ RMS each).
How accurate is that calculator? For 2 15" subs with an x max of 22mm it say I should have almost 15"diameter port. The most I can fit is 2 6"Ports and that will be with a relatively small box. 5.5cuft net.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Did you use the calculator here? http://www.carstereo.com/help/Articles.cfm?id=31
15" port is a little big, but not a lot. I did a quick calc and came up with 135 sq in. Two 6" ports is only going to be 56 sq in.
Builds:
That's got me curios. But yeah I used that calx, 2 15" drivers with an xmax of 22mm comes out to 14.8 min diameter. I would have to use 2 7.25" round Ports. There is no way I have room for that...
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Well if I did the math correctly (2) 3" ports give me 6 inches of port diameter which is what the calculator is calling for.
I can't use larger ports because the length required to get the tuned right it ridiculous, like 60 inches.
(4) 4" aero at 4 inches long would give you the port area you need and the correct tuning. And that wouldn't take up much displacement wise...
  • Who's Online   0 Members, 0 Anonymous, 8296 Guests (See full list)
