Soundstream xxx 18 help plz
Nao
Same thing just happened to me. It sucks, but your best bet is to cut out the cone, put the screws back in with loctite, and get a drop in recone
Did you have the same sub
Email soundstream and see if they have any recones available. If not I would go with psi.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
you arent taking it out without ruining it. It just isnt happening. There is no way to torque the bolts to the basket and a motor.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
is there anyway u can take the kit out without breaking it?
i'm sure there are guys who can do this
i use acetone to soften the glue and then chisel and hammer to get it out
I've tried loooots of stuff because I was in your same position.
Acetone also ruins the glue/shape on the spider. Doesn't do a great job of dissolving CA either. Chiseling it off chips it. Also distorts the spider.
Using a solvent such an xylene for the rubber adhesive that holds the surround proved ineffective. I'd be worried about it weakening it too. It's just foam after all.
Then there's a matter of getting the dustcap off. Tough to do without either A. cutting it out and destroying the dustcap -- they are THICK too. Cutting it isn't easy. Or B ripping up the laminated layer of the cone with it.
In all honesty your best bet is to just cut it out, replace the bolts on the motor (blue loctite this time around), and recone it. Depending on how old the sub is you can also email SoundStream and see if it would be something that's covered under warranty. That being said you'll likely have to ship it to them - not such a bad idea anyway if you are afraid of reconing.
I thought soundstream had to change the name of it to the x3 because of RE audio's xxx searies.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
just recone it bro. New sub, new happy times.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
  • Who's Online   1 Member, 1 Anonymous, 1628 Guests (See full list)
