Slammed Dodge Challenger Sundown/CT Sounds Build
so i got the new box built
was thinking bout doing two bracing rods but i opted for one
cut the holes, very close to the port. this caused some issues
its so close the router cut through the port wall so i had to do a lot of sanding to make sure there wouldn't be any contact with the sub and wall
Messenger_5836566123310242688_1391545801
finally screwed the floor to the riser. its much more secure and stable now
applied some bondo
and it fits!
now i have it in with the subs and wired up… first impression… in terms of sound quality it sounds much better, it hits the lows much cleaner without sounding like its unloading and its not as muddy. however in terms of loudness its still not there… i actually have to turn the volume up more now than with the last box to get it really cranked up and hitting the notes. Im guessing once i get it tuned properly and fully 100% sealed off with foam it will be louder because i probably have some cancellation going on.
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
So i took a little video… it hits the lows well like i said but its weird how it isn't loud but it still can be felt. When i had my two type r 12s in my truck they were relatively loud and they made the inside of my ears itch. That box was tuned kinda high, but this isn't quite the same. Its not as loud per say but it still can be felt like it moves a little bit of air as well. Maybe I'm just not use to low tuned boxes...
  • XS Power D3400
Build log:
TEAM GOAT
Can't tell how loud it is from the video. I'm pretty curious how mine is gonna sound. Not gonna lie, I'm kinda nervous, haha
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
Just out of curiosity, if you're worried about the sub being so close to the wall, why not just cut a new one? Or add a baffle and move it over. I can't see the video here at work, but the rest of it looks good.
Its not a problem now, i just had to sand a lot to be safe.
yeah videos can be bit deceiving because all cameras pick up is distortion of bass so its no way to gauge it. for 8s it hits the lows very well.
i think I'm gonna spray foam to seal the trunk today… I'm kinda nervous :ehh:
  • XS Power D3400
Build log:
TEAM GOAT
If it isnt sealed 100% it will be quieter. I forget the difference exactly but in my car it was in the nieghborhood of 2db which is alot.
Try pushing the box all the way if you can. Still facing the smame way and everything. Just slide it straight back as far as possible and see what you think?
Im not sure how you have your trunk layed out if sliding it back is an option, itd be and easy quick test.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Dang. Your gonna foam it. I would try to lay down some painters plastic or tapr off the entire area or something.
So the foam seals against the car without ruining the interior and could be taken back to stock easilly.
Something like that. Foaming a beautiful car is kinda wo crazy crazy imo lol.
Setup:
Xs D3400/ Xs XP3000
I agree don't get foam all over. Idk I keep thinking if you want it louder and deeper bass why not go with a single 12" mine slams hard on the 1400 .1
For some reason I can't see it getting super loud on two 8" . I may be wrong. Hope sealing it off get you what your looking for.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
haha well i already laid out the painters tape months ago planning on foaming just the edges around the structure. i don't think it would be that much foam and all the areas it would contact are covered with tape already.
And i honestly think i got my hopes up a little too much with the 8s i mean granted they are loud for 8s, but cone area is king. i might eventually go with 10s or 12s
  • XS Power D3400
Build log:
TEAM GOAT
heres a video from today as well
  • XS Power D3400
Build log:
TEAM GOAT
