Slammed Dodge Challenger Sundown/CT Sounds Build
Wellllll I finally got started on the build once again…heres the latest
I got me a cheap new jigsaw, it gets the job done.
Got the false floor wood cut out
and
well well well… i found out this stock 8" woofer's true purpose…holding my light while i work at night lol
after cutting out the false floor piece I figured out the necessary height of a spacer to make that floor piece level. This is what I came up with. Now time to secure this piece to the car
secured with two lag bolts from the sheet metal beneath.
this thing aint going anywhere. even with all my weight pushing against it it doesn't wanna budge
Im opting to use expanding foam as additional support beneath the false floor for extra bracing towards the front of the floor piece. Since I know I'll most likely change the setup and want easy removal of the foam I lined the surfaces with tape.
Also got the battery tray floor cut out that will sit in the spare tire wheel well area. It still needs to be secured and possibly painted? It won't be seen but it might be nice having it painted black
I also got the dimensions of the battery tray cut out. Its not glued or screwed together but you can see what it'll kinda look like. Theres room for another two next to it when I go to add more.
More to come soon.
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
Got a little more done today before I go to work.
Test fitted the battery
Threw some rattle can paint on it. Once I get another battery I might fiberglass it all and make it fancy with some real paint
Drilled the holes in the sheet metal and in the wood for the bolts to bolt down the outer surround of the sealed portion. Here you can see them attached but not tightened on all the way to test the fitting
As you can see its gonna need a good bit of foam or pre caulk on the edges of the surround to fully seal it off. I got the wood cut as close to the shape of the sheet metal as possible but clearly not good enough.
The last picture you can see the lines drawn down the side of the false floor where the two panels will go that will extend down about 3/4 of the way. The opening between the these two boards is gonna be 31.5", exactly the width of the enclosure so its gonna be a tight fit. Im still figuring out how I'm going to seal the area above the box in the front of it. The enclosure will sit about 8" recessed from the front of the false floor. This will give it just enough room for the subs to be mounted inverted as they are exactly 7" tall from the basket to the bottom of the motor and 8" accounts for the slope of the seats.
  • XS Power D3400
Build log:
TEAM GOAT
looking sick bro nice
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
thanks mane. Im excited about it coming together. The only thing that aggravates me is one of the bolts on the left side won't seat level with the other bolts so it looks off. i don't suppose it will matter too much as it should still tighten down fine but it just looks weird while you can see it.
  • XS Power D3400
Build log:
TEAM GOAT
Looking good man. From my experiance with my 300 (they share the same interior as your's)... if you put the port on the passanger side and leave the passanger side rear seat up.. The system will sounds louder to the ear.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Thanks dude. Well my original plan was to have the port in the center since I hoped to screw the box to the pieces of wood that run down the side of the false floor and I would be able to do this from screwing inside the box, with a port anywhere other than the center I wouldn't be able to access the sides of the box to screw into. But since the fit will be so tight I might not need to screw these pieces together. I was always told that port on the driver side would be louder but I plan on experimenting with a couple different setups of boxes so Ill just see what sounds best with various layouts.
  • XS Power D3400
Build log:
TEAM GOAT
Well with the rear passanger side seat up the port would load off of the back of the seat and come out the rear driver's side seat area. Idk... its been the loudest orientation that I've found.
**40/60 rear seats... 40 covers the port and half the sub on my setup and the 60 is completely open.
