my question is will 1" mdf thick enough for 2 18" btl'z in a wall or should i double the front
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
yea, definately double everything.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
i would say definately double it,
my baffle is a total of 3.75" plus 3/4 all thread for bracing. Make sure i keep the level 5 18's on the box and off my head if you know what i mean.
banner2.jpghttp://www.DCSOUNDLAB.com/01 Chevy Silverado X-CabPioneer 4900 in Dash3 Stinger 2150'sIraggi 260 amp Alt.1/0 Stinger Wiring(2) DC lvl 5 18's(2) Hifonics Cyclops10 cu box tuned to 27hz
the way i look at things...
if its worth doing, its worth over-doing!
overkill and audio are oxymorons.....
i likes me some audio stuff...
you cant build it to strong.
When you think its strong enough, just make even more stout.
I have been studying enclosure building for some time now and found this from the JL website many years ago, it still stands true,
"THE JUMBO TEST
Imagine, if you will, a rather bitter mid-sized African elephant named Jumbo (how original) that has been taking steroids and lifting religiously for the past 10 years. Jumbo's ex-girlfriend left him for a box (don't ask--because we don't know) and so every time Jumbo sees a box, he does his best to obliterate it.
After building your enclosure, you should be able to place your box in front of Jumbo and let him tap dance on it all day long knowing that when Jumbo finally gives up (he never does) your enclosure will emerge unscathed. It sounds a bit extreme, but it's true: strength is key!"
Now if 1" MDF is too expensive where you are, look into doubling up with 3/4" MDF. I just cover one sheet with wood glue and screw down the other sheet on top of it. I also clamp all around the board to make sure it is together 100%.
Edited by ShawnAndrewMAC
i thank it can
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
