I have an SD-2 10 D2 in a sealed box on an RF P500.2. I play stuff like decaf to drowning pooling and I love the sub. Very impressed for it being a shallow mount sub.
me too I got 2 of the 10 with a t1000bd amp in a reg cab dakota both sealed and they hit the lows real nice it plays decaf real good
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
an jacob told me the 10's perfer sealed over port and the 12's perfer ported over sealed
2 sundown sd-2 d4
flex tech
box design by Joe X
I have an SD-2 12" in a sealed box and it is rather impressive ran off a RF Power 501bd. I only have my gain around half maybe less and it sounds real nice. I can only imagine in the proper ported box it would have higher output but it also depends on what you listen to. I listen to more rock than rap so the kick drum bass is amazing in my set up. Also it is processed with an MS-8.
That's 3X rated power, travel at your own risk. I know I personally wouldn't but that's me. Just set the gain to proper voltage to get RMS or slightly above after checking with DD1 or Oscope to find clip point.
the most I would feed a sd-2 10 is 600-700 I got a t1000bd at 1ohm on 2 10's they seem to be more hungry but I don't have the electrical to brovide this amp, I'm running all stock beside the big 3 but I might be getting a deka to replace my batt
2 sundown sd-2 d4
flex tech
box design by Joe X
Isnt it actually 750 to each voicecoil? Dual 2 ohm coils wire parallel. 1500 total off the D6.
to much it'll last 5min if that, feed it 300-350rms each coil to make it a 600-700rms total, its rated 500rms total which is 250rms each coil.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   1 Member, 0 Anonymous, 2570 Guests (See full list)
