Cablguy needs help from the SMD / MECA Bassheads
OK ... Cool !!! Thanks guys !!! Looks like we have the Term Lab covered !!!
Now maybe we can try and figure out what MECA SPL class to run in ... If I need to post any more pics (for vehicle modifications), I will ... just ask
With a blow through...you will be in a mod class. So sq in of drivers + fuse amperage for sub amp
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
Indeed you will be in mod. I assume those LP amps are a/b? This may hurt you on fusing but you can probably still get into mod1 of you can hold a fuse
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Most likely this will be set up with a pair of 15s ...
Yes, the amplifiers are Class A/B ... One amplifier for each driver 4 ohms mono.
Then again ... I may run a single Linear Power LP2400 if it is avaliable be then ... 8 ohms mono.
So can you guys sort of explain this fusing thing to me ... I know each amplifier has internal fusing (three 20 amp fuses) ...
(not sure about the new LP2400) ...
each class has a number associated with it. for this example I will use Street 1 as it is the one I am most familiar with
the number is 550
this is the maximum cone area + 10xfuse
so say you have 1 12" sub this is about 113 sq inches of cone
so 550 - 113 = 437
437/10 = 43.7
43.7 is your maximum fuse rating but since you are allowed only one fuse in street 1 you have to run a 40 amp fuse or less
external fuses are mandatory don't worry about on board fusing
one thing you really need to check on is the iso mounting of your subs. they may count as 4 drivers instead of two
either way worst case scenario
Mod1 = 1000
10" subs = 78.5
78.5 x 4 =314
1000 - 314 = 686
so 68.6 amps of fusing
I am not sure but I think mod1 can run two fuses (check the rules on that) in which case you can run 2 30s or do like the pros do a 60 amp and a 5 amp
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Mod1 = 1000
10" subs = 78.5
78.5 x 4 =314
1000 - 314 = 686
I will be running a completely different setup than what I have installed now if I decide to do this ...
My Iso-Kits will be used elsewhere ...
If I can get my hands on the enclosure I'm looking at ... I would be running a pair of 15s
Your best bet with 15s is mod3 top scores are around 153 to 154 if you could drop fuses to mod2 and still do a 150 you will be very competive in spl to but if you are looking for bobos mod3 you need to do park and pound for bobos as well tho and that's 30 seconds ave on music full tilt meter 6 feet from the car
the mic sits on the seat, elevated on a stand, a few feet from the windshield. you usually want to hold a tone for about 4 seconds just because the score could go up a tenth or two. maybe that's not a concern for you.
Ok ... Makes sence. I'm going to assume that the mic takes the place of the driver's head (ears) ...
... and what do you mean when you say this ???
the mic placement likes lower frequencies.
If I can get the enclosure that I have in mind (already built in another truck) ... I think it is tuned aroung 40 htz (I really need to verify this ASAP)
I will be able to give more details on this (and the drivers) if I can get my hands on this enclosure to put in my truck ... Not sure at this time if it is even possible to get this ... But would be nice, It is a well built enclosure !!!
But it's things like this I need to know if I need to actually build an enclosure because I kind of want the highest frequiency possible cause lower frequiencies tend to "destroy" interiors ... Trust me, I know from personal experience ...
Now I can say this about the Blow Through setup ... I will be fixed below the windowline to where I can completly cap it off for Sound Quality competition ... Don't want the SPL drivers making any unwanted frequiencies during testing / judging ...
1000w at 35hz isn't going to destroy anything man. trust me, i know from experience lol.
Thank you Sir ... This sound about like my game plan
Yea, low 150s is all I'm looking for, just want to stay in a low enough class so I won't get ma but kicked by a raw SPL vehicle and my does Sound Quality also ...
I do not have or will have enough battery power for this ... nor do I want to put my truck through that kind of punishment ...
I'm thinking just a burp should bump me up ...
I am a retired meca spl judge you can pm e questions any time..... I also did meca sq judging
Thank you Sir ...
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
