shepherd92683 Posted November 19, 2013 Author Report Posted November 19, 2013 Any suggestions on an alt based on information given? DC is out of my price range unfortunately. 2017 Honda Accord Touring Build coming soon
finkster Posted November 19, 2013 Report Posted November 19, 2013 Did you ground directly to the alt casing rather than the block? Give that a try and see if it helps. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
DubNDodge Posted November 19, 2013 Report Posted November 19, 2013 I still don't think he should have that much drop. I have a 120a alt a d3100 and d925. I drop to 13.1 on a 90 degree day. With a 2200 and 90.4. How do your grounds look OP? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
truthsayer Posted November 19, 2013 Report Posted November 19, 2013 What size wire to rear. CCA or OFC? Your alternator is stock it needs upgraded. How long do you run it at full tilt? pictures of grounds? Did you remove any wires off the alternator (stock)?1/0 to the rear. I know I need to upgrade the alt. it will happen one day lol. I did not rove any wires during big 3.What do you mean used to? Did you change anything?It seems to have happened more after I upgraded my boston amp. It just doesn't seem that running it stereo at 1.5 ohms like the last one I had would be that hard of a drop. By used to I mean within the last 6-8 months and it's been steady since then.If I add another hc2400 and a 270a mechman would that be sufficient to run as a daily if I upgrade to an sq 3500.1? That should do it. truthsayer
HHR Ed Posted November 19, 2013 Report Posted November 19, 2013 Check your Kinetik battery to make sure it is holding a charge. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
shepherd92683 Posted November 19, 2013 Author Report Posted November 19, 2013 Grounds are solid. Somedays it will float while driving 13.6-14 other days like today it floated 12.4-12.6. I don't get it. Shouldn't there be more consistency? 2017 Honda Accord Touring Build coming soon
shepherd92683 Posted November 19, 2013 Author Report Posted November 19, 2013 There also was no change in a bad way after I did big 3. Actually gained about a volt. 2017 Honda Accord Touring Build coming soon
HHR Ed Posted November 19, 2013 Report Posted November 19, 2013 There also was no change in a bad way after I did big 3. Actually gained about a volt. Stock alt is PCM regulated. Shuts off when it senses batteries are charged and also when temperature gets too high. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
shepherd92683 Posted November 19, 2013 Author Report Posted November 19, 2013 There also was no change in a bad way after I did big 3. Actually gained about a volt.Stock alt is PCM regulated. Shuts off when it senses batteries are charged and also when temperature gets too high.Mechman told me that an external regulator would keep my battery light on but I'd like to have one... And not have my battery light on. 2017 Honda Accord Touring Build coming soon
shepherd92683 Posted November 19, 2013 Author Report Posted November 19, 2013 Mechman emailed me and suggested the G series 250a. Anyone have experience with that alt? 2017 Honda Accord Touring Build coming soon
