best cheap subs.... best cheap high excursion sub?
exxxtrem
So I prob did 100 hrs of research before I decided the best cheap sub is..
Hifonics hfx12d4 35$ (black sub chome hf)
Now if this build goes correct I will want to swap the hfx for a good high excursion 12 thats CHEAP but good. Keep in mind cheap. Searching ebay seems like next step up is lanzar. (had 4 15s in a cavalier wagon 18 years ago and they pounded) prob because of the us amp though.
So cheapest high excursion sub thats deasent? 12
Im open minded. Just looked at sundowns cheapest sub and saw its 12mm double the hf or even kicker. I love airmovement so thats y I went with 6 of the hf... if there are subs with double the hf excursion 3 would be equal to 6...
Cheap and good never go together.
But you can have the shiniest of the turds for sure.
A side note, a box guy should come in here and explain high Xmax vs "normal" on subs. After hearing that explanation I'd like to know what you expect to get out of these high Xmax subs.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Good luck you will be replacing again.. You may want to look at RE Audio Sex line.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I run quality here so my voice coils don't smell. I buy once not twice. Thank about that. I can run 1 HCCA 10 inch and blow a 135 on TL. Sit back laughing here.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
