Amps without fuses????????
BASShead12
So I bought a crescendo bc2000d and 1/0 gauge to run to it and do big 3. I noticed the amp doesn't have fuses on it do I need to put another fuse closer to the amp besides the fuse next to the car battery?
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Mids/Highs: Alpine SPR-50c 5.25" components
Mids rear: Alpine SPR-69 6x9
Mids amp: Alpine MRX-F65
Power/Ground: Massive Audio 4 AWG
Signal Cable: Massive Audio 14 Gauge
RCA's: Monster cable
Subs: 2 Rockford Fosgate HX2 12's
Sub amp: Crescendo BC2000D
Custom box - Herculiner with Silver port
Big 3 and power/ground - Sky High Car Audio 1/0 OFC
Coming soon:
H.O Alternator Singer or Mechman
Yes, you do. In your owners manual it should give you the recommended fuse rating.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Great, thanks for fast reply
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Coming soon:
Yes you do, some guys put them by the battery and inside. What size box do you have for the two RF 12''s ?
4 sq ft total ported
Yea man make sure you buy legit fuses and fuse blocks otherwise the ratings could be off and you might not get full power ran all the way to your amp
No doubt man. I bought sky high 1/0 ofc wire, fuses, blocks and terminals.
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Coming soon:
No, you don't need 2 fuses.
You only need 1 fuse on the positive wire going to the amp, and it should be as close to the battery as possible.
A legitimate ANL would cost quite a bit more than the ones that are represented on the car audio market.
Ones for car audio are almost all just fuses that fit inside of an ANL fuse holder.
These are true ANL fuses:
http://www.cooperindustries.com/content/dam/public/bussmann/Electrical/Resources/Data%20Sheets/Bus_Ele_DS_2024_ANL.pdf
But buying something from SHCA or other sellers will work fine.
Krakin's Home Dipole Project
  • Who's Online   0 Members, 0 Anonymous, 684 Guests (See full list)
