Anyone with cap bank install?
I got mine from a local place. Either of those would work
TBH you can use 1 watt resistors. No need for 10 watt. I just got them because I found the size easy to work with. Something like this would do. Or any of the ones you posted
http://www.mouser.com/ProductDetail/Vishay-Dale/RS01A50R00FE70/?qs=sGAEpiMZZMtbXrIkmrvidNU7x4nnwrw0G2W4a2PA4y8%3d
And nope, nothing else. That is my balancing circuit :)
so say I bought an AGM battery with the big 3 upgrade on a 120 amp or bigger alternator would I be able to buy 2 supercapacitors like the ones @banginhummer posted
would that work on a 2k RMS system?
Personally I'd spend the extra couple bucks and get these
http://www.ebay.com/itm/Maxwell-BCAP0010-7-Ultracapacitor-Surge-Booster-assembly-/370937036668?pt=Battery_Chargers&hash=item565d91ff7c
is that look like a good set to run with a singer 350alt and 2 or 3 bats to power 4k watts and still stay around 14v
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
All I want to say is if you are unsure of what you are doing, dont fully understand the purpose of these and dont understand the basics, i wouldnt put supercaps in your ride. they can be dangerous if missused.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
how do you know how many banks or banks of what size you would need with your equipment. like ok i wana run well say 8k rounded up in my neon. the biggest h.o alt i can find atm is like 220 im trying to find something bigger i plan to get a xs power d7500 for where my spare tire is and something big but maybe not that big up front. now i have room for 2 other batteries on the size but not something terrible large. maybe there d1400 on each side but i have a fairly small area where i think caps would work well behind my box. so whats the math as to what size bank i would need for an 800 ish max amp draw. this is a daily car. not a burp
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
I like 100-200 farads for every 1000 watts, personally.
And don't mix a d7500 with a d1400. A d1400 is a 14v battery and cannot be used with a 12v battery. Use a d3400 instead :)
I was pretty sure that when you wire them in series that you add the voltage but the farads stay the same, like if you have 3 - 2.7v at 3000 farad and wired them In Series u would have a setup that could handle a charge up to 8.1 volts with a storage of 3000 farads still, not 1000 farads. Otherwise If you had 3000 caps in series you would have a circuit that would be able to charge at 8,100 volts and only have 1farad of storage from what u were saying
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Never mind, I did some readying, that is right
Pioneer 4300DVD
2 banks of 6 2.7v should support 3-5 k depending on alt my 1000 amps of alt an 6 d1400s plus 26 caps does pretty good on my 2-8 ks @.35 only drop .3-.6 full tilt
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Damn have I got some learning to do! Lol.
I thought capacitors had their place in car audio.
It seems that here in Australia, a lot of people are still stuck on what they are actually used for...
100 farad per 1000w rms! The people that do tell me they work, recommended to me 1 farad per 1000w rms???
So here I am to get schooled!! Lol
Now I take it that the 1 farad cap I bought is not the type I want to be using? Or is it?
Will it be ok to use for music based system?
Appreciate any help you guys can give.
Cheers, Jay.
  • Who's Online   1 Member, 0 Anonymous, 1582 Guests (See full list)
