ok yesterday i took my system apart to clean up the wires and run my new 4channel Memphis amp. i reran all the wires the same way used the same grounds everything Is the same. but when i turned my system on my subs seemed to be at half power. is that because i now have 3 sets of audio cables running to my deck and there stealing power? 1 front 1back 1 sub. I'm kinda pissed spent 4 hours doing this And now i dont know how long its gonna take to fix!
2 jl 500/1 v2s 2 alpine type r 12d4 00gage wire 150fuse jvc deck 2.5volts
Memphis audio amp for my type r components up front and jl comps inthe rear please help before i rip everything back out
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
If you had the battery disconnected, it may have reset some settings on the head unit.
Eclipse cd7000
Maybe the SW control on the head unit was reset to 0. Turn it back up.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
that's the first thing idid was reset all my hu settings. Is there a way to test my ground from my amp?
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
i just had a customer come in with the same issue. I looked at the setting and there was a switch for the input sensitivity 1x or 10x. I flipped the switch back to what it should be and problem solved. see if your Memphis amps have the same selector.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
the ohm loud hasnt changed plus it wouldn't matter there dual 4ohm subs so 2ohm or 8ohmwouldn't matter on my amps each sub is going to its own amp. and yes they do I'll check that Tmrw. would that affect my subs amp tho?
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Wired to 8 ohms would make a difference in output as the amp is meant for 1.5 to 4 ohm nominal for the 500w, and where 8 ohm is outside the limits causing your loss in power.
Nothing lost or gained in checking to make sure you have it wired @2 ohm.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
my speaker wire never came out of the sub plus there magnet out and the type r have the jumpers so i know there fine. and yes the polarity is switched.it has to be the ground that'sthe only thing i can think of. its just 2 hours of work to get to it Damn
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
just redid all my grounds and removed that amp and the problem is still there? there's either something wrong with my amps subs or car electrical system. i don't get it. everything is the same way it was! teaches me for trying to improve my system,
ok i went to my local audio shop and got new ground wire. drilled threw the floor in my truck and went right to the frame. removed every single piece of wire from the 4 channel amp. rewired the system once again and boom full power. i fihonestly think it was the remote wire from my deck. but don't care it's working
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
