xbox connection issue.. please help
my xbox has been in the same place forever. the router has been in the same place forever and now for some reason my xbox will not stay connected to my router. it keeps losing connection and then it takes me resetting the modem/router to get it to connect again. sometimes that doesnt even help.
my laptop which is in the same room is still connected and has full internet access.
why would this all of a sudden be happening. ive tried numerous things. but the xbox will always fail connecting to the router.
any suggestions? or advice.
btw im not really computer savvy
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Its because xbox one drops Friday
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
my xbox fails at the first step on the connection test.
it doesnt even make it to live. how would that affect it?
Is it wired or wireless connectio
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I had problem with the slim I just erase the router on the xbox and reset the connection been working fine since.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
its wireless.
ive tried resetting the network settings to default. and clearing the cache 3 times. and erasing my profile and redownloading it when i randomly get connection.
but so far nothing has worked.
i keep getting an ip address error
Turn off DHCP on the Xbox and give it a static IP. I always do that for any device that needs forwarded ports so I don't have to constantly change the settings. I think it's trying to give your Xbox an IP that has already been assigned to your computer or other device
I let my router assign the first 50 or so addresses for DHCP (192.168.1.2 - 192.168.1.50 on my router), and I use anything outside of that range for static IPs (like 192.168.1.137)
2016 Ford Focus SE
No build log yet
DC Audio 1.2K
2x DC Audio Level 2 10"
have you tryed unplugging your router for 5 mins from walland all other connections then plugged it back in??? this fixs the problem 90% of the time
yeah it sounds like the router given the same ip to other devices unplug for 5min it should reset the router ip config
2 sundown sd-2 d4
flex tech
box design by Joe X
