Amp per coil?
DeLuna
If you had a woofer that was rated at 800w rms d2 coils, could you wire one 800 watt amp to each coil, or would you have to wire a 400w amp to each coil for a total of 800?
400 per coil. But you would have to make exactly sure both amps are tuned perfectly in sync with a CC-1 and a DD-1, though I've heard people tuning amps together with digital multi meters ? Though I don't know how they could do that. Or get amps that are strapable. Though, it would just make more sense to buy an amp that does like 800-1k at 1 ohm. Unless you like the look of two amps.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Each coil on a DVC driver is half the rated power. Impedance doesn't matter.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
an 800W rms woofer is 800W rms total. 400W each coil.
But I would just use 1 800W amplifier to both coils.
Make sure it's a 1ohm stable amp.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
You cab also run into phasing issues with 1 amp per coil.
At this power level, it's typically easier to run either a single amp, or a pair of strapped amps. But not wiring individually per coil
If its possible I would strap two 9k's per coil then turn the gain to 100% on each of the four amps. Make sure your video recording all of this and you post here for us to see :)
Just kidding... well not really i would love to see that but besides that.... dont do it.......:D
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
