Need help with enclosure
JuniorXJ
new to the forum but been into car audio for the last 10 year but never got into the box build but im looking to build a better box than the prefabed peice of crap i have now. ive done some reading and i looks like i should have a box with 2.5 tuned to 32hz , thats where i get confused. i have put info into a few online calc and they have just added to the confusion. im good with tools, numbers not so much so i need some help.
the setup
98 Jeep cherokee 4 door
12" Alpine Type X
crappy kenwood amp pushing 500w rms (looking to upgrade soon to at least 1000w rms)
pioneer avh-p4300dvd
max demensions
40W x 22D x 18.5H
i could go up in height bt would like to keep it even with top of back seat
sub up and port back
1998 Jeep Cherokee
Headunit: Alpine CDE-143BT
Eq: NVX XEQ7
Front stage: Boston Acoustic 6.5 Component set
Rear stage : Removed
Mid/High Amp : Pioneer GM-X364 70x2 bridged
Subwoofer: Fi BL 18" Dual 2 wired @ 1ohm
Sub Amp: CT Sounds 1400.1d
Build: http://www.stevemeadedesigns.com/board/topic/180586-juniorxjs-98-cherokee-build/
Good first post, you gave all the information we need all at once, which folks almost never do.
I'll work up a design for you today or tomorrow, you should have enough space for what you want to do.
Builds:
A net volume of 1.5 cubes (after sub, port, and bracing displacements)
(1) 6" aeroport at 38" will get you around 35hz tuning.
Krakin's Home Dipole Project
I've lost my touch on box building, even with Subwoofer Design Toolbox. It's freaking all confusing now (maybe its the age)... lol. This box for example,
http://www.stevemeadedesigns.com/board/topic/141-ported-box-2-mtx-9515s-repost-for-my-site/
how is something like this even calculated? Given how the ports are being shared. As for tuning, is it tuned for 30Hz @ 2.80cuft? I got the specs from
http://www.manualslib.com/manual/293713/Mtx-Thunder-T9515-04.html
Can anyone get me back into speed?
You calculate the volume of the box as a single chamber.
When designing a 2 common wall port like that you split the port in half at the back wall, so that half of the port area goes to each driver. Being that the port shares two walls with the shell of the enclosure you need to account for that (Torres will if you select it).
You can refer to this thread for some more info.
http://www.stevemeadedesigns.com/board/topic/178345-calculating-port-area-with-xmax/
I forgot to ask but did you want this box to have 2.5 cubes net total or per driver?
Bonus points for driving an XJ. :-)
Builds:
I don't see where he says there is more than one driver, unless I just don't see it, and 2.5 cubes is a lot past the manufactures recommended specifications.
Regardless my suggestion is for a single Type X 12".
Thanks for the responses , it's a single 12" and I know the manufactures spec say a lot less but I was surfing around the web and have seen a few post said 2.5 would be better for this but I'm not sure ( not sure if they were talking 2.5 gross or 2.5 net )
Alpine recommends gross 1.8
And 1.15 net ,
1998 Jeep Cherokee
Eq: NVX XEQ7
You can take my net volume with a grain of salt as I have no experience with what these like volume wise.
  • Who's Online   0 Members, 0 Anonymous, 379 Guests (See full list)
