Custom material sub boxes
Thumper
Hey guys,
Got a question that I can't seem to get a straight answer out of my local shop or guys so if anyone can give me a straight answer it would be much appreciated
I'm trying to set up a pretty mean system in a smallish car (While still keeping the back seats and at least some trunk space), the trunk is a pretty odd size and dimension so a standard MDF 1" to 1.5" thick sub box just isn't going to fit, I've got a bit of experience in fiber-glassing and carbon-fiber work and am thinking of making the sub box out of composites, will this still sound as good? or will I end up with too much flex in the box and the bass'll end up sounding like it's at the end of a tunnel)
just don't want to waste time and materials with experimenting, so like I said, any help would be appreciated,
Thanks
Build it strong enough and you'll be fine. There are thousands of systems out there with boxes like you describe. Just like a wooden box if it's built correctly it works.
Static drops are my bag.
Thanks heaps for that, just been a struggle to find any boxes that aren't made of wood (living in New Zealand, things like that seem pretty exotic)
Use fiberglass, make the design to a nice shape. use enough layers to make it rigid. And you are good to go.
You can also reinforce the resin by adding sand and portland cement but it's not needed. For broad flat areas, brace with wood or steel.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Well if it's small, I don't see why 3/4 is being used. I've seen many people think nothing could fit in there when reality is the options are there. Maybe pictures and specs or dimensions?
Where in NZ are you at bro? I've seen a bunch of fiberglass enclosures, mostly at shows but I've also seen one that was removed from a show car and it was fairly thick and really strong. I bet for the same thickness fiberglass would be much stronger. Fiberglass would be great and I'd love to see a build log of what you do. NZ :woot:
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
