What sub(s) should i buy
conbon
I have a Rockford t1000-1 thats puttin out 1500 watts at 1 ohm. What sub(s) should i buy that you guys think would be the loudest. I drive a 2004 mercury sable ls. it has a fairly small trunk opening which is the only downside. Just give me some pointers and options! Thanks boys.
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
Just look for a sub that can handle 1000-1500 Watts and loom at reviews for the speakers you can find.
Also figure out if you want sq or spl and look up what subs are better for that application.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
A single 15" will likely fit, post your max box dims that will fit through the opening or if you can remove the backseats, a box can sometimes be put in place from there.
I would look at the soundqubed subs. Hdc3 15 is rated for 1500w rms or you can get the hds3 that are at 1k I think. Need to go and look again.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   0 Members, 0 Anonymous, 6292 Guests (See full list)
