Regular Cab truck Box
Unless you want to sacrifice more leg room or run 8s ported. By the time you figure sub and port displacement, you're not going to have enough room for most 10s(definitely no 12s)
OP you have gotten some good advice that i concur with, seeing that i have a regular (single) cab pick-up. Your design is pretty much same as mine, but its for a single 12''. If you plan on going ported you deff wont have room for two 10''s or 12''s. Sealed would just barely give you the space for two 10''s. I personally would do the two 8's as suggested, thats in my future plans also. You do have the room for Two 8's in a ported enclosure and they will do wonders. Anyways that's just my 2 cents, good luck on whatever you decide.
truthsayer
I know two 8's doesn't seem like it will sound that great but in a nicely designed ported box it will sound waayyy better than stuffing 10's into a tight box. What kind of music does your friend listen to? Maybe one 10 with a good amount of power? I have an extra cab (not much more room) with a single 10 in a ported box I built and am hitting 137.9db sealed. Also sounds great on music so I'd say either of those options.
I beg to differ I got a reg cab dakota which are smaller then the full size truck running 2 sd-2 10 in separate box each about .7cf I had to let the seat up 1 click and I'm 6'2 still got leg room.so full size truck should have more room for a bigger box then mine.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Anybody? Its this or a ebay special prefab
With some slight modifications it can be done, NOT saying is necessarily the best option but it's still an option, the following is just a concept and is not meant to be built:
Tuning: 35 Hz
Net Volume: 2.3 ft^3
External Height: 16"
External Width: 60"
External Depth: 8.5"
External Depth2: 5.5"
Slant angle: 79.4 deg.
Ports:
Number of Ports: 3
Pipe Port Diameter: 3
Pipe Port Length: 18
External Length: 5
One other option may be 3 SD-2 8", I wouldn't recommend sealed unless you have listened and liked it before.
Run two Sundown E12s sealed in 1 cube each. If not, pick up some heavier hitting 8s, like the SA8 and go ported with around .60-.75 cubes per.
Listen to some regular cabs and see what you like. I've been sealed and ported and prefer ported. I definitely didn't hate sealed though. I like the better low end and little more output of the ported enclosure in the trucks I've done.
If you are going with SD2s then stay sealed. SD2s were designed for great output in small tight sealed enclosures where there isn't room for a ported box. Perfect for trucks.
09 F 150 Supercab
2 Sundown Sd-2 8s
Rockford r-750-1
Rockford 6x8s
Rockford r-250-4
Pioneer avh1500
Big 3 upgrade
That sub can also work perfectly well in a ported enclosure though. It isn't strictly for sealed.
  • Who's Online   1 Member, 0 Anonymous, 731 Guests (See full list)
