I used to run the brutus amps, great entry level amps, they do not make rated power, that kicker amp does more than rated power all day long.
my buddy has 2 12 L7's 07's and a brutus 1200.1 amp on them and man that bitch pushes them like crazyyyyyyyyy and he only has the amp half way and bout pounds them out the box
if they needed a fan then they would have a fan,
why add unneeded crap it just brings price up even more
Why do people consider amp gain as a volume knob....??
this seems like another one of those threads where no matter whats said your not going to listen
bottom line the brutus amp doesnt do rated power so it uses less amperage
like david said it takes power to make power
there is no magic amp that uses very little amps and massive amounts of power
and like accordman said if u dont wanna take our advice then just do wut u think is right and dont listen to the people that know
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Now Why Do You Say Brutus Are Over Rated And Kicker Is Not
Kicker Is Over Rated But Not alotttttt kicker you got to have like 4 batterys and 2 alternator to push it to it full power
brutus you need like 2 batts and you will push it to it's max
brutus does what is says
Have you actually tested the output of either amp? I owned a kx2500.1 and it... bout pounded a BTL out the box. That doesn't mean it was giving out max output.
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
i am listening to everything and thanks for all of you that replyed but i just really do not know if i should keep the zx2500.1 or get a different amp?
b/c right now i am useing it to push 4 15 L5's it sounds good but i nnnnnnneeeeddddd a high out put alternator for my grand marquis and then i will really see what that amp will do
i already got the big 3 dual batterys and 0ga wire running back just need the alternator
no i have not tested the output but when i get the amp back from getting fixed and reconditioned i will test the output and let ya'll know
This topic is now closed to further replies.
