That Loud Focus...USAlternators Hairpin, 4 DD 9515i's in a B pillar on 2 Soundstream XXX-15K's. Caps and Lithium Power. New vids
i actually might just try 15's in the hatch. i mean worst comes to worst i can recone or just build into a c pillar. idk. but i need to figure out the whole box situation,
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
I would try to see if you can do it without walling it. If not you can just wall it then.
2000 Ford Focus ZX3
Mods:
Raceland Coilovers
Borla Exhaust
Aftermarket Header
System:
Sony CDX-GT66UPW
Pioneer 6x8's
System Upgrades :
Pioneer MVH-X560BT
2 sets of Rockford Fosgate P1683's
Fi Audio Q 18" D2 ( Currently Own)
DD M1C ( Currently Own)
All SHCA Wires and stuff...
XS Power 4800 ( Stock Replacement)
High Ouput alternator (undecided which company or Amperage.)
you say 6-7 cubes. would you have to build the box in the hatch? would you go over the tire wells? how do you get that much room?
If it is okay with you I will post some pics of the boxes that I used in my car and the scores they did with the equipment that I used. That way you can see exactly how they fit into the vehicle and get an idea of how you will be able to do so yourself. Also as far as SPL is concerned there are several tricks that I can tell you about with this vehicle that will help gain almost up to a dB on the meter without increasing equipment or power.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
if you going with dd, 3 10s is most cone you can fit back their otherwise you just wasting money on power and subs and box.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Ya so idk if I can do 15's in the hatch. That is if I go DD. So either switch brands, or......idk
Pioneer HU
Actually 2 15's fits well, but my loudest setup in the car was 4 12's and they fit just fine. It takes some trial and error but it is capable of being done. Each setup was musical as well peaking in the low 40hz range.
1 XS Power D3100
Audio Control LC6i
Stock Deck
He is talking about DD subs. 2 DD 9515's would need about 8 cubes net. otherwise I would do 2 15's in the hatch for sure. btw ya you can post pics up. curious
as to how you did it.
Pioneer HU
I had a diagram of the hatch measurements before but they where on my computer that took a shit.
The trunks very slightly in size but roughly
41" wheel well to wheel well
30" bottom depth
17-18" top depth
20-21" high
Between the trim pieces at the top 28-30" if i remember right
The trick is to angle with the seat but manage to have room for batts and amps.
Some box specs I'm playing with
40" wide, 28-30" bottom depth, 20" tall, 17" top depth. Port sub up port roughly 15.5x5-6" 15-20" long
32-35" wide 28-30" bottom depth 17" top depth 21" tall aero port playing with both 10" and 6" port ideas port to driver side subs up
Similar as above but slot port driver side full bottom depth 4-5" wide unknown length.
That's what I.can think of off the top of my head as to differs ideas in going to play with. Also have one from nightshade I'm going to try out.
The bwnifit I have is only running 3800rms total. No need to have tons off batteries. Using the new RF mini power 2 & 4 channel amp with 2 1500.1bdcp. Roughly 250amperage draw on music from what RF tech has said.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
30" bottom depth
17-18" top depth
20-21" high
run a couple banks of caps. that will be plenty. and 2 banks is smaller than a d3100.
Pioneer HU
I will post pics when I get home from work. However, the box that I ran 2 15's in for daily was 7.6 cubes net, so I'm sure there is another .4 cubes that could be eeked out of there to make them work.
1 XS Power D3100
Audio Control LC6i
Stock Deck
