Can someone explain how to find the square inch per cubic feet when designing port?
osiris10012
Using Small's port area formula you would want 20.25 sq in of port for this driver at 35 Hz. If you use a well flared/aero port you could probably cut that back to closer to 16 sq in. I would suggest you use the 3.5" wide port for greater port area.
Builds:
Looks like I need to start redesigning my enclosure. Thanks for the advise. I am also considering doing a forward firing port and sub, but until I get the sub in hand to measure the actual size of the magnet I don't know if I can make it work. Also am I doing the additional port length correctly by adding half of the width (3.5) to the length for the 90 degree bend?
Remember that the paper suggests having a reasonable amount of flaring along with the area.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Yeah I wish I knew what exactly a "reasonable radius" was that he was referring to in that paper. I would guess its like a 1/4", with fully flared slot ports I try for a flare radius equal to the width of the port.
Builds:
When you guys are referring to flaring the port, do you mean make the opening kind of like a flared aero port, but with the slot port? If so how would you determine how much flaring you would need?
Yeah it's kinda like an aero port. When I am going to only be flaring one side, like on a box with the port against the side, I make the flare radius the same as the port width. If the port is in the middle of the box so both sides will be flared I make the flare radius 5/8 to 3/4 of the width of the port.
Builds:
woopisie wrong thread lol.
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
