heres one that'll throw you for a loop
so i boot up my computer one day and it is only reading half of my ram size and only one of my GPU's.
read ram size through control panel> system> view ram and processor speed.
read GPU through EVGA precison and Nvidia control panel.
i have 32gbs G.skill 1600 ( OC 1866) actually installed. only 16 show up now ( it read 32 from march to nov 30th, 2013)
EVGA GTX 580's 1.5gb SLI
MSI Z77A-GD80 mobo
thermaltake 1275w PSU
i have swapped GPU places and same thing.
I have swapped RAM and still shows 16gbs.
That gets rid of the ideal of them being bad.
now..
i have the normal bios and the Clickbios that i can use to change settings to the bios when windows is already running.
Startup bios shows 16gb installed. Clickbios shows 32gb installed.
CPU-Z shows 32gb installed
DxDiag shows 16gb installed
Task manager shows 16gb installed
The ONLY thing that i can even remotely think of is that a GPU buss and dual link RAM slot have gone out on the chipset on the M77A.
I have returned everything to stock settings ( no OC on anything)
same readings either way, OC or stock settings.
i took a multimeter to the PSU and its testing out with proper voltage.
onboard test spot for the MOBO test out with proper voltage, onboard debugg lights display a 55 like normal.
There are no swollen caps on the MOBO and the south bridge feels warm to the touch after a 19 hour gaming session. which, i'm assuming is normal.
ANYBODY think of anything that i may have missed?
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
First things first. Did you jiggle the power cord
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
windows 7 64 bit prof
MSI Z77A-GD80 MOBO
and yes, i did more then just jiggle the power cord lol
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
forgot to mention, BIOS and windows is up to date with everything. also, all drivers are up to date as well.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
I had a similar MSI Z77 mobo, same issue
Reset everything back to factory, (write all your settings down before you do) in the UEFI and in the normal bios.
reboot, set everything in the bios back, then you should be fine.
tried that. pulled CMOS battery, hit the reset button the mobo and still same thing.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
Really? It sounds like bios shadowing is enabled. If you reset the bios though and it only sees half . . . did you try manually setting your ram voltage and timing? That's what I'd do next. And turn off XMP
yup. i have tried setting it by hand and nothing. heres the funny thing, the ram is 1866 Mhz OC but the bios will only let me go to 1600 Mhz.
i have literally tried every little thing and nothing, reset bios to factory and nothing, so i went update by update for bios and nothing still. it is blowing my mind. on board voltage test spot for RAM is measure 1.5v so i know that it is getting proper volts.
Ubuntu is showing 32gb but.... gnome3 is showing 16gb.
i'm just going to have to RMA the board in febuary.
i cant afford to be without a computer with my online school work.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
