Measuring@Headrest vs. Dash
Meka
Im thinking my truck would rape a headrest metering.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'd like to see it happen! :)
It's all install dependant.... But like what others have stated, generally headrest = lower frequency (MECA) & dash/sealed = higher frequency (dbdrag).
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Headrest would be about 8 inches in front of the port
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You'll be surprise.... my 4th order wall port is about the same distance to the meter (port on driver side) and not much of difference in score vs sealed at the dash, just frequency.
I wish I knew more about this stuff.
Last comp I was told to burp 47hz after I did my sweep. That box sounded loudest at 37hz. This box sounds loudest at 33hz... So I wonder if my peak lowered.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
That's the annoying thing. Loud to the meter and loud to the ear don't always agree. I doubt you're going to want to burp at 33hz, but then again what do I know ??
Put it on the meter is the only way to find out. A 150db @ 33hz is completely different vs 150@ 47hz. If you judge by ear, 33hz will sound twice as loud as 47hz.
I compete in Meca and have for a couple years now. with all things being the same, 39-47hz is the sweet spot for Meca, seems to be what the meter likes at that position. I burp at 53hz in Meca and do a 150.4 (unofficially) and a 149.4 last season was my highest score. In IASCA, sealed on the dash I was .4-1 db louder, due to higher tuning. I consider under 30hz burping to be tuned low for Meca. Most of the competitors that have walls put the port on the driver side and meter at the driver headrest with passenger door open.
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Well I guess good thing I'm not going to be competing officially. However I will have burp and music numbers after TD. burp numbers off my usaci CD. And I got a few songs I wanna see what I hit.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
