My small build , "New Focal component set" Pg 89
Its all about having the right tools... :)
I agree with that 100% but i can always find a way to get it done with what i have. Just takes longer and hurts more! Ya know us old guys and all!
Kicking ass and taking names man. Is your truck a 2.4 liter 2RZ Tacoma?
Oh the performance potential if it is :)
Going to be heavily paying attention to this and bcbrassard's threads when I upgrade in the winter... :)
Was just looking at your door panels and i must compliment you on your creativity and wood working skills on those doors. Nice work.
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Yes it is a 2RZ 2.4 The only thing I have done is an LCE header and K&N filter. Nothing will be done to the engine for about 9 years when I retire. I need it to commute in.
Thank you very much.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Ok started the last coat of filler on the doors. Is this smooth enough for a bondo application??? LOL Now the sanding will be done by hand and block. I did put the first coats on the speaker rings. I will get them smooth then install them to the door. Then I can run some around the bottom of the rings and make a nice little curve finish to the door. Then primer and paint YEA!!
Oh and I had planned on testing a piece of MDF with the color I want then with a clear coat on it. I just want to see what it will look like with clear. The rear of the door will get a few coats of clear just to seal it off from moisture.
Oh and look what showed up today.. :)
80prs
DC 180 alt
I just use that as an excuse to buy more tools.....
80prs
DC 180 alt
Lots and lots of sanding later the door panels are in primer. The speaker rings are in final stage of filler before primer.
So I was down there waiting for bondo to dry and sanding staring at the door panels. What I have decided to do is wrap the door panel in some tan vinyl. Then paint the speaker rings with the paint from the sub box for contrast. I have the confidence that I can wrap the door panels. I cant wait to see how they turn out.
I will attach the speaker rings with bolts through the speaker rings into the door panel. I will do a counter sink bolt front and rear so I can remove them later if I decide to change something in the future. It will be very secure and look bad ass with no exposed fasteners. :)
80prs
DC 180 alt
day off from door work. To tired today. I did buy more 100 grit paper, the same paint I used on the sub box and some clear. I will do the speaker rings in that color but want to see what it looks like cleared. I will maybe do a test spot later.
80prs
DC 180 alt
Continuing working on the door panels. I have come to the conclusion that I love body filler. Well Evercoat Rage. I like the process of sanding, fill, sand a little more, fill slight imperfections, sand, primer, fix little imperfections, sand and paint.
Its very relaxing to me to sit out in the garage with a beer and music to just sand and make things look great.
This is after final sand before primer. I went 100, 150, 220 then primer.
Shot of the center.
After primer
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 899 Guests (See full list)
