FreeZzy Posted December 11, 2013 Author Report Posted December 11, 2013 here is the picture and size of trunk if you can not see the text that I wrote ( Lowest part in trunk but if i put box more on front of trunk i have little more space like 1" )
FreeZzy Posted December 13, 2013 Author Report Posted December 13, 2013 So ? For box size somebody can help ?
alaskanzx5 Posted December 13, 2013 Report Posted December 13, 2013 Will those 15"s even fit side by side on a 30" wide baffle? I think the baffle would need to be around 36" for the subs to fit side by side. IMO, that trunks would be better with 2 12s or a single 15. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
CleanSierra Posted December 13, 2013 Report Posted December 13, 2013 ^^^^this. I doubt it. If they did, where does the port go? Im not the one you want to try to troll. Just a fyi for you.
FreeZzy Posted December 13, 2013 Author Report Posted December 13, 2013 yes it fit The port go under that 2 subs ^^ or maybe i can take 2 JL 13w7 ? but RF T2500.1 is enought ? The trunk of Charger SRT8 2012 is bigger than mine? Because this is my next car and i want to keep my subs for my next car ..
CleanSierra Posted December 13, 2013 Report Posted December 13, 2013 I'm dumb I see the pic. Forgot it was there. You're gonna build it in the trunk? Im not the one you want to try to troll. Just a fyi for you.
FreeZzy Posted December 13, 2013 Author Report Posted December 13, 2013 Nop, i have 19.68" open space in trunk so the box can be build outside of trunk ... But i don't know if i put 2 RF 15" or 2 RF 12", there is a big difference? except size of sub ^^
alaskanzx5 Posted December 13, 2013 Report Posted December 13, 2013 The full diameter from edge to edge is something like 15.6" that and up to needing at lest 31.2" from side to side in order for them to fit. According to your measurement you have 30.7 unless you do sub back. That trunk really looks like a great front firing sealed opportunity though. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted December 13, 2013 Report Posted December 13, 2013 Oh and if the box id facing back you won't have much room for the sound waves to get passed the box and into the cabin. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Joe X Posted December 13, 2013 Report Posted December 13, 2013 OP according to some rough calculations your box won't fit in it's way in despite the size of the trunk opening. The smallest box I could come up with is: 19 3/4"x 30 3/8" x 31 1/2" (HxWxD) which specs: 6 cubes [email protected], 108 square inches of port area, looking like your drawing only with a dual layer baffle. To be sure you need to build a cardboard dummy box and test fit, if it doesn't, go for 13.5s or 12s OR build inside. You are not the first one that thought it fit and didn't or the trunk lid couldn't be closed.
