Passive vs Active LOCs
When I got the amp for my mids/highs I got a cheap PAC LC-2 line output converter from a local electronics store. It works alright, but with the low power output of my stock Nav I have to have the amp gain almost/all the way up (set with test tones and dmm/ear). Besides being able to keep the gain lower, which might reduce some noise, is it worth switching to something active like the audiocontrol LC2i(~$110 w/remote)? My sub amp is running off the factory subwoofer output tapped from the HU connector with some female molex pins, so I don't need the bass restoration stuff.
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
I have an lc2i with remote connected to my vw and also just helped a buddy set one up. I connected it to front door woofer leads right out of the factory amplifier and have good output with my Rockford t-1000 with zero gain for my sub. Never used it with Mids/highs and have never had a standard LOC but i dont think i could go without it after using it in three different vehicles with good results.
I can vouch for the Rockford BLD. It's a damn good LOC.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
where is the knob set to on your LOC?
I usually run mine all the way up on the lc2i. But if your asking what it controls its output voltage to the amplifier and not a bass boost. I set mine up on full and use the knob only to take away if necessary.
