How too ground and power 4 batteries together
Quick question
4 kinetik 2400 in the back and a 5th one up front under the hood! How to connect them all?
Ground the 4 batteries in the back too one location all 4 sharing the same ground location?
2nd question
One power wire from front battery to one battery in back then string the next power wire to the next and the next and so on?
Yes. Front battery...fuse.............wire..............fuse.....rear battery.
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
Glad i said something.
fuck yes. On the run from battery to battery bank you need TWO FUSES. One at the front battery, (as close as you can get it, for protection) and a SECOND on the rear bank. Again, as close to the battery as you can.
Think about it. With one fuse, if a short happens, the rear bank will still be hot. Feel me?
Can some one draw a pic ? and post it?
This is very important.
Running multiple batterys, with a lot of amperage, will burn the vehicle down with the quickness....
You can run a ground wire from battery to battery then ground the last battery in the bank to the frame.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
