SQ/AQ questions
CleanSierra
I talked to a guy at the last show I went to N8 and it was same exact truck as mine. He said resonant was 46 Hz I believe
I am also here if you got any questions you aren't sure about I have messed with the hdc3 so much I know every possible failure point and what works and what doesn't work.
The alum coil is worth the money if you plan to put 2k per sub otherwise copper coil is plenty for up to 2k.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Andrew, I'm so glad you stopped by and have me a comment. If I end up getting these things, I don't plan on sending more than 2K to it. I'm trying to be competitive(if I qualify) in Street2 MECA. I know you have EXTENSIVE experience with AQ/SQ and have done multiple setups.
So being that these are just Couple of 10s, would 37Hz tuning give me a good combo of being able to play music and put up some numbers into the mid 40s? My plan, if I end up getting these subs, is to run two 5" round ports made from stacked MDF rings and build in a progressive flare on each end of the port. You think twin 5" ports fired at the B-pillar would be enough port, possibly TOO much port for practical purposes? I appreciate any and all help, thank you :)
Your rf can change based on enclosure you in thr vehicle etc. His rf may get you close but it still may be different
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think that is a great place to start and play with adding or removing port to get your number dailed in. Then once you find the magic port that works for your vehicle adjust subsonic to help with loading when you play music.
37 hz is a "safe" tuning to start off, those 10 will want to peak high probably upper 40s into the 50s hz range, just my experience. And that was in a trunk car off a AQ2200. They will take awhile to loosen up to so keep that in mind. As they loosen peak will change a few hz.
Evo X build log
Thank guys. I guess I'll build an enclosure to the outside dimensions as I would for the box with 2 10s. I'd like to do the testing the old school with a sealed 10" sub with a Total Q of .707. I doubt that testing other ways would bring any or much difference.
The crap part is, the class I want to compete has a 2 batt limit and I'll be limited to an 80A fuse. If I want to bump to Street3, I can fuse how I want, but the competition will be deeper.
I'm not sure about the SPL only(in reference to the Aluminum coils)but it would be good info to have. This could be a burp only setup, I've not really made up my mind yet. I don't know what they'd sound like daily. I've heard them get loud, but never daily on low tunes for music. It's not like I can time low and expect the cone area to pick up the slack for lower frequencies with only 2 10s. I know low tunes aren't suggested with these things, if I was gonna run them daily I'd do something like 36 or 37Hz. Comp only would be more like 46-49. Maybe removable ports even.
I can say this about the subs for daily music. My 1 12 sounds amasing. I listen to mostly country and rock and how it sounds with thise style of music is amasing. Some times when i want lows i know mine will play down to 30hz with ease and i have it playing down to 25hz. At that low it still sounded good just not as loud lol.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
What is the size of your box and port tuning? I just built a box for my hdc3 12 and it came out to be 2.76 cf and the port is tuned at 35.3 hz
I got the box info from someone at soundqubed. I could lessen the box size a bit by mounting the sub inside but I want to mount it inverted so I will get full box volume out of it as I have heard or read that these subs like bigger enclosures.
Am I correct? Thanks
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
My box is 2.6 cubic feet tuned to 36hz thats after all sub and port displacement so i would say just mount it normal. But yes they do like bigger boxes i just think almost 3cubes may be a bit to big. Maybe ami or someone can shed more light on this
141 on music.
Do you know what the displacement of the HDC 3 12 is?
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
