ok, so this is going to be a real slow build with no real progress until sometime next summer (hopefully June). going through a lot of changes at the moment with a whole lot going on.
anyways list of equipment I already have
(2) t2d415 (in storage different state)
(2) punch pro 6.5 (installed)
(2) punch pro tweets (installed)
(1) t400.4 (installed)
(1) pioneer 80prs (installed)
(1) t1500.1bdcp (in storage different state)
(1) 10 farad Rockford cap (installed) ( yeah ive heard about caps, personal exp it has helped slightly with keeping voltage up)
enough Rockford 0/1 gauge to do 2 runs and big 3 (1 run installed no big 3 on this car yet)
plenty of 16gauge for the doors (installed)
should have enough 4gauge for the amps
singer 250 amp alt ( currently sent back for repair and external regulator setup )
fuse holders/fuses
hx2 power 12" for a temp setup im going to hopefully have a box for it and installed soon.
things I still need
batteries ( for sure either platinum diehard or kinetic for cheaper price but proven performance)
either t2 or t3 component set
2nd t400.4
2nd t1500.1bdcp
smd volt meter
material for fiberglassing
wood, nail gun, wood glue, liquid nails ( in general box building tools, materials )
8gauge for speaker wire
lots of sound deadener
not a whole lot on that list some spendy items that will take time to get but it shall be done.. sooner or later...
the plan is to do an all Rockford build with decent sq and great output. not building for the meter but if I can get up to a 148 I would be especially happy. going more for my personal enjoyment and dedication to a great hobby.
performance build
what i have (installed)
aem cold air intake
aftermarket exhaust manifold
2.5"? (looks last owner did it im gonna make changes) exhaust from manifold back
tein lowing springs
rear sway bar (looks kinda like an eibach but don't know, aftermarket for sure though.
light weight pulleys ( going to put a stock crank pulley back on because of the harmonic balancer )
what to get
kyb adjustable shocks and struts
all new bushing through out the suspension
engine and tranny mounts
clutch/fly wheel
minor head work maybe raise compression a bit
tune
appereance
cant remember the name of the stuff right now but that paint that peels right off when you want to change colors...
hid fog lights
hid headlights ( have but not on this car yet )
carbon fiber hood (installed needs touch ups)
carbon fiber hatchdoor ?maybe?
tinted windows
18" enkie wheels (installed)
ill have to use my phone to add pics give me sometime for pics. for some reason i cant paste to this forum, works with everything else on my computer just not this forum.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Had a single t2d415, stock electrical and no sound deadener at this comp and.around a 142.3, could have been much better IMO. Voltage drop like crazy and sub and port was fitting back, I've had better luck firing up.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
And this is the planned box for the 2 t2d415, will be a tight fit but I'll make it work.
[int]http://i1229.photobucket.com/albums/ee475/alaskanzx5/t2d41526inchports_zpsca15b6d3.png[/img]
I'm going to use pvc but I will flare it and i'm going to sand and paint the inside of the box ti make it nice and smooth. Not set on that coloring but it should be something along those lines.
Just noticed, in the sketch up the height measurement doesn't include the double baffle.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
472311_378176212216979_100000738091815_1
552718_384203748280892_100000738091815_1
Don't like the projectors.on the headlights very much so i'm thinking of doing a retro fit.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Ive got some changes coming next summer also. Mostly a front stage change but i am planning on sealing the box of better also. And i have one of those diehard batteries. The g34. That with my 130 amp alt i dont drop below 13v when reved to ~2000 rpm.build looks good. Are you back in alaska?
The box will be a pain to fit and get the trim pieces back on, not to mention the back seat latching in place. Had a box at the same height and depth before but 38"wide, it took work to get it all in and the trim pieces back in place. I'll make it work though.
I'm still in Michigan, there id a chance that I might go back to Alaska next summer. Not sure right now, or should I say the wife isn't sure...
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Box for the hx2 12 i'm going to use temporarily.
designed by cleansierra
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1289 Guests (See full list)
