Opinions/Advice Wanted 12's to 18"
Jbarrera93
just make a plan and stick to it. I have had several different build plans get half way done and change my mind. gets old doing that.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yea more than likely gonna go thru with the single 18" for now and make my way towards a 4th order wall :peepwall: lol. Girlfriend wont be happy with it but oh well!
2001 Chevy Blazer LS
Kenwood KDC-HD552U
2 12" SDC 2.5 D4 Fi SP4 18" 4 Sundown SA-12's
HiFonics BE 1200.1 Soundstream RUB1.2500D Looking for a 5k
XS Power D3100
4 Soundqubed 6.5's (Pro Audio)
2 Soundqubed 3-Way 6.5's
2 Soundqubed Super Tweeters
If you are running the sdc 2.5's they can take about 1k each daily if you know what your doing so Imo just getting the 2200 would be the better/cheaper option. If you just switch subs from 2 12's to 1 18 there is a chance it would be louder but its not known for sure due to so many variables that must be factored in.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
If you do go with a hdc 3 18 you can not do a 4th order you need to do a 6th order. Soundqubed subs are not meant to be in a sealed box and will ware out the suspension really fast in a 4th (all from soundqubed)
141 on music.
Yea we will see how the output changes with the 2200 and go from there. I would more than likely save and get 2 18's instead of just one so I don't keep throwing money away into building enclosures.
Kenwood KDC-HD552U
XS Power D3100
Electrical upgrades before the AQ2200 I'd say. better sell the little guys than pop them, but in the end cone area is king, 2 15" would fit best if going for a 18" go for a cool one, 2 12s and one 18 have rather similar cone area.
x2 on the electrical.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
yeah, 2 12s is roughly 224" and 1 18 is roughly 254", its such a small difference that a difference in output would be hard to notice unless in a real nice box imo.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
THE EBP tells me, at 62, that the 18" HDC3 CAN be run in a bandpass 4th order. The suspension is stiff, but a properly designed box CAN make them perform perfectly fine in a 4th order bandpass enclosure.
Im just staying what soundqubed told me when i questined them about a 4th order. You can but the sub will not last as long as it should.
141 on music.
  • Who's Online   0 Members, 0 Anonymous, 1014 Guests (See full list)
