alenv10 Posted December 29, 2013 Report Posted December 29, 2013 Trying to decide which amps i want to run and i cam across these! Does anybody have any input? I need a matching set of amps for sub and mids Re Audio usx45kv1 http://www.sonicelectronix.com/item_68122_RE-Audio-USX-45KV.1.html I would be running this at a 2ohm load, for 1000watts, aiming for 600-800 so will just turn it down a bit Re Audio usx 4250 http://www.sonicelectronix.com/item_68120_RE-Audio-USX-4250.html planning on powering 4 crescendo audio pwx's NOTHING DOWN HERE YET OBSIDIAN FTW
hazestorm23 Posted December 29, 2013 Report Posted December 29, 2013 These are decent amps . What are your concerns? Or questions
alenv10 Posted December 29, 2013 Author Report Posted December 29, 2013 These are decent amps . What are your concerns? Or questions I just havent seen many people use them.. and with the plexi glass bottom cover, can i mount them with the guts showing then? or is that considered upside down and harm the amp ? NOTHING DOWN HERE YET OBSIDIAN FTW
hazestorm23 Posted December 29, 2013 Report Posted December 29, 2013 There is actually a couple people on here that are running some they seem to like them. As far as displaying the amp upside down I guess in a way you could but due to the heat it generates you have to be carefull where you mount it so it doesnt burn anything and a couple of fans could help as well.
newls1 Posted December 29, 2013 Report Posted December 29, 2013 oh lord, looks like RE Audio is trying to go back to the grass roots of usamps (which they bought the name back in early 00's and ruined it) with the plexi bottoms again. My input is this; If you think you're going to get 1000rms out of it, i sadly think your mistaken, i can be wrong now, but i doubt it I love my staffie So anti FACEBOOK it isn't even funny
thefourth Posted December 29, 2013 Report Posted December 29, 2013 I cant see them doing rated Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
alenv10 Posted December 29, 2013 Author Report Posted December 29, 2013 It wouldn't bother me not doing rated, because really what im going for is 600-800 watts, so if it is over rated thats fine, which i believe it is. just questioning if i will be able to show the guts, will it over heat? will it last? the sub amp will be wired at 2 ohm load, powering only a single obsidian audio v3. and the mids/highs amp will be powering 4 crescendo pwx 6's NOTHING DOWN HERE YET OBSIDIAN FTW
newls1 Posted December 29, 2013 Report Posted December 29, 2013 you need not worry about overheating if you mount it upside down, she'll be fine I love my staffie So anti FACEBOOK it isn't even funny
Miguels Posted December 29, 2013 Report Posted December 29, 2013 you will only see 500 watts out of that amp at 2 ohms and for the price you can get better http://www.ebay.com/itm/CT-Sounds-900-1D-amp-amplifier-900w-RMS-2000w-MAX-Class-D-1-ohm-stable-/111125887108?pt=Car_Amplifiers&hash=item19df9e7884 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
gattiboy13 Posted December 29, 2013 Report Posted December 29, 2013 All I can say is I ran these RE amps. I ran one that was suppose to do 1000RMS on a 600RMS sub and it would not push sub much at all. It gave some bass but would top out once turned up and was under powering sub. Go with something better, even hifonics would be a better choice.
