single xs d3100?
i had a kinetik 1800 600 and stock group 48 batt on 1 t1500cp and dropped down to the 11s still with ofc 0 gauge wire all around and big3 0 gauge ofc
all cars are different. I think kinetik sucks though the d3100 may be able to do it ;)
i own both XS batteries and kinetik and they are both good.. my brother has 2 hc 2000 and drops to only 13.6 with alt charging 13.9 to 14.0 with a DC alt.. when he was clipping it was dropping to 11 v so its safe to say you was clipping.. me with my mechman alt and the adjustable voltage wouldnt see below 14.4 on my kinetiks
you was clipping or your stock group 48 was the reason why you was dropping bad
Gain was all the way down since I didn't have access to a dd1, the t400.4 was set with a dd1.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No bad boost either. The stock engine ground is crap and the ground on my cap was just to sheet metal.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I have a Rockford 10 fared carbon cap that will only be hooked to the 2 1500.1bdcp amps with a short of wires as I can do. Going to have dual input for the cap made and i'm thinking a 3rd run ti a distro block for the 4 channels.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
0 gauge to 4 gauge reducers for the 1500.1's now since I think of it to
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
probably the under the hood battery if anything, i set my gains with the dd-1, and yes i know how to use the tool lol
every car is different. I also didnt have the best ground. and my alt was tiny.
Wish there was a way to figure out what voltage drop would be. At 14.4th according ti the math from that video it would take roughly 400 amps in which i'm sure a single d3100 plus the 250 amp alt would do the trick.
Of course bit knowing voltage drop though I don't know what amperage it we need to make rated power.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Not including rise. I'd just do the single D3100 and see how it goes from there. Also I know you said you had a dealer close but Mechman offers a 5% discount over the phone with free shipping in the lower 48. If that helps
Yeah i'm just trying ti get a rough idea of what i'm looking at fir needed power supply and what my voltage will look like. Once the box is built and in I know I can squeeze a small battery or 2 in some how. trying to figure it all out the best I can so I have a general idea of what to expect.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3289 Guests (See full list)
