2006 Corolla (Da C) Loud and & clean system install from day 1 to now ( BEYMA,ORION HCCA, SELENIUM & more). New floor carpet and Fatmat entire floor
Those tails look WAY better. Any pics of them lit up?
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
when I get out of work on Saturday, I decided to buy the wink mirror which is the 5 panel mirror to replace the small OEM rear view mirror . I got this mirror because it helps you see ALOT better and covers all blind spots. I went to Pepboys and Picked up the last one and put it on. The wink mirror shakes even if u hit the smallest bump so I'm going to have to add 2 more brackets when I have time to eliminate the shaking.
Before
After
Ok 20 question time lol
Did you do your own headliner? How hard was the process?
In the pic of the Acura, is that aftermarket carbon fiber vinyl in the interior? If so which one. Looks stretchy and good over contours.
why the big mirror? Looks good, but doesn't it create a blind spot thru the windshield?
Ok ok done with question time. Haha
Looks good, still tuned in, keep it coming
Also... You forgot to blurr out your plate on the "finished" set of pics ;)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
lol im going to do it now @swordlordboy1234
@Jnells Yes i did my own headliner and used a 4 way stretch vinyl which allowed me to stretch it over contours and made the install easy. Taking the headliner out was fairly easy and i just basically started on one side sprayed the 3m adhesive spray and used the roller and made sure i didnt leave any bubbles. Once i was done i left the headliner out to dry for around 3 hours in direct sunlight. In the tl that is aftermarket CF, my boy got it a roll of ebay and it worked like a charm you can heat it up with a heat gun to make it stretch and it holds up really good. The big mirror i always liked it for some reason and it also helps with all the blind spots you couldnt see with the oem rearview mirror and with the this one you can REALLY see everything once you put it on, I can see everything happening when im driving from the back left all the way to back right with the wink mirror.
Yea the big mirror isn't really my style but blind spots must be a thing of the past for you haha. That CF job looks good and it may have sold me on doing the same.
Those keyhole tabs are pretty sweet! Almost like they were made for your car too with the color.
Btw sweet Js too, got a pair myself ;)
