So I've been seeing a lot of back and forth between the -5 and -10 track just set my gains with the -10 should I be worried about hurting my equipment
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
if you know the songs you play and are willing to accept the risks, then do -10.
if you play a bunch of decaf/bigpimpin, then -10 is pointless.
I play a little decaf but mostly regular music and usually not full tilting all the time ^^^ yeh true it does cause some confusion
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
I set my shit with the 0db track. Honestly, I don't know why the device was offered with option when it s meant to help prevent clipping/distortion.
I could be wrong but I think most music across the dynamic range not just bass is less than -5db.
people were going to do -5 and 10 anyways
Yeh had a dmm and set the line driver to like 5.5 then I used the dd1 on the amp, just curious what tone should I have played to set the line drivers voltage I think I had it set with a 40 0db track from before and just left it then used the -10 track on the amp
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
I just came in from playing with my DD-1 I noticed that setting my full range with -10 is no good. To much distortion. -5 is perfect. I had the sub set on -10 but really the same thing. -5 is good to go.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
I use -10 but know when to back off on the volume
Used to have a loud truck
