Impala-Chasing a 50 on the TL-Build log (Rockford Fosgate,Soundqubed,Alpine,Sundown)
This is my seventh gen impala i'm building. I'm not all the way serious about the 150db thing, as it would take alot of fun out of it, making compromises. It would be sweet though.
Blew the type S 15's you see, many many pictures yet to be added.
Equipment:
Soundqubed-3500D.1
Rockford Fosgate Punch 500.4
Alpine type S 6.5 & 6x9
Knuconcepz 0 and 4 gauge, distribution blocks and krystal RCA's
Pioneer-DEH X8600BH
Sundown X 12's (yet to be ordered)
774848_601630296520865_412576969_o_zps8c
X12_001_SSA__41724137523224112801280_zps
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
Im going to try to fit a huge kinetic or D3100 in the factory spot under the hood. and then another kinetic in the trunk.
how do you like that 120.4? Im slacking pretty ridiculous on mid's and high's. Have you taken the back off of it? i would love to see what its like
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
You going to do port subs forward in a sealed off trunk? A lot if petiole get loud in sedans like that.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
forward facing port into seatback. partial seal off from the trunk
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
why not fold the seats down and do a full seal off.
I use my rear seats all the time. Will it function properly if I cant give it the open cabin to fire into? am I better off firing into the licence plate again?
I guessss I couuuuullddd... maybe give up the rear seats..
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
Sealed trunks can still use their back seats. It's all in how you build the box and seal it off from the trunk. Look at sealed trunk build fir ideas
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Box Design credit to: Bassink
What do you guys think?
Some fiberglass, the recommended bracing, and a double layer baffle facing the seats?
6 cubes tuned to 31hz with 93in2 of port area.
Should look like this
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
