Is a 4th order wall usually louder than a ported wall?
Keveeno
I read that each order is supposed to gain three db. I may have heard it from my extreme car guys. Either way that is what I have read or been told.
Also saying a fourth has a larger bandwidth is laughable. Plot one out and look. They are louder so the wide bandwidth is perceived not true. It's like saying ported has a wider bandwidth than sealed. It just isn't true.
i guess i meant louder across a greater bandwidth
Would that account that a vented enclosure is still a 4th order? Just not a bandpass.
Edit: for the 3 db gains
i think that is why it is labeled a bandpass. it is slightly diferent.
orders still exist and the 3 db applies but there are two types, bandpass and non
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
In that situation then, if true, then a vehicle with a ported wall would meter higher outlaw style than sealed up on the dash(acting like a 6th order), which is like the rest of the topic is getting to...sometimes true and sometimes false.
With that same false logic, one could build a sealed wall to meter outlaw in a manner that would act like a 4th order.
/fucktard logic. Build both compare 4th vs ported
From personal experience, i havent had much difference in a db perspective, but the 4ths i've had always have a much larger range, lower notes.. With your subs being in a sealed enclosure within a port, being sealed in a sense suffocates them so they may have a tad bit higher power handeling, and being across from one another they build pressure off of each other. If you have the know how, i prefer 4th over ported. Obviously just a little more tricky.. Lol
  • 4 years later...
Old topic but im gonna reply anyway since half the comments are from people who have never built or heard a proper bandpass in their life and like to pretend they’re experts.
   Flat walls have a peak around tuning and drop off quickly below it and slowly after tuning, they’re easy to build and take up less space.
a 4th order if built correctly will play a bigger bandwidth than a flat wall, the tuning, port area, and size of the front chamber all dictate how high it can play, and the rear sealed chamber dictates how low the box will play.
A 6th order that’s built correctly is much larger than a 4th order and has an even bigger bandwidth due to the 2 tunings. The  rear chamber is tuned low and has a peak, it rolls off below tuning and rolls off slowly after tuning, in which case the front chamber picks up the slack and has another peak because it is tuned higher. From my experience if you want the best range of notes it’s best to tune your front chamber one octave above the rear one, so that way when your lower chamber starts to get quieter and quieter the front chamber naturally starts picking up the slack and it gets louder.
   I’ve seen people tune them at 23/46 and have a huge range of notes they can play with authority, this box is also the most efficient because both chambers are ported and it is using the rear and front wave of the subwoofer unlike a 4th which uses only the front wave
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
