Aj11 Posted January 10, 2014 Report Posted January 10, 2014 unless you drive a del sol i doubt the type s will hair trick. i have 3 type rs and don't hair trick. given i have a Durango but still and i have almost 6x the watts jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
deathcards Posted January 10, 2014 Report Posted January 10, 2014 I guess my final question is: Can my old power1000bd handle this as a 1ohm load if i don't turn gain up more than half way? gain is used to match voltage coming from the rca's on the head unit just making sure you know cause distortion can kill your sub (more heat) and amp(overworking/heat) also your ears skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Guest Posted January 10, 2014 Report Posted January 10, 2014 the amp will give 500w at 4 ohms and the woofer is 500w and you can wire it to 4 ohms....what's the problem here?
Rck'nRF Posted January 10, 2014 Author Report Posted January 10, 2014 the amp will give 500w at 4 ohms and the woofer is 500w and you can wire it to 4 ohms....what's the problem here? The sub is good for 1500watts,500watts nominal/RMS,wanted to push a bit further than a lowly 500 is all Kranny,you know,an attempted hair dance..
Kyblack76 Posted January 10, 2014 Report Posted January 10, 2014 wire to .5 and hair trick like a boss SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted January 10, 2014 Report Posted January 10, 2014 the amp will give 500w at 4 ohms and the woofer is 500w and you can wire it to 4 ohms....what's the problem here?The sub is good for 1500watts,500watts nominal/RMS,wanted to push a bit furtherthan a lowly 500 is all Kranny,you know,an attempted hair dance.. 1500max. give that woofer over 1k and you'll probably smoke it
Guest Posted January 10, 2014 Report Posted January 10, 2014 2.6" voicecoil. the sundown sa is rated at 600rms. you really think your type s is going to soak up as much power as you're trying to give it? you'll have a long lasting air freshener that smells like shit for three weeks. aka coil stink. if you want to do a somewhat decent hairtrick without having the windows 3/4 of the way up, double the power and get more powerful woofers
Ahmed Johnson Posted January 10, 2014 Report Posted January 10, 2014 You should wire it at 4. That amp gives you the right output for that sub at 4 ohms. Buy another one just like it and you can max that amp without a problem.
sbg Posted January 10, 2014 Report Posted January 10, 2014 wire that sub at 4 ohm for the 500watts. That sub will not take 1500watts man. Save your self from blowing your amp from runing at 1 ohm and blowing your sub from being way over powered. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Aj11 Posted January 10, 2014 Report Posted January 10, 2014 don't want to sound like a dick, but if you hair trick off a type s on 500w I'll eat my subs! i don't think you could hair trick if a girl put her head in your port! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
