DC Sound Lab
i wanna build a 4th order in a 99 Infiniti I30 Limited (same as maxima) ported thru the skihole..
i want a single 12" and wanna run 2k rms to the sub.
Would the Level 4 take the 2000 daily? r upgrade it to XL parts to handle it??
or would the XL12 work in a 4th order bandpass? because DC site doesnt give the XL sealed specs and 4th orders are better for sealed subs..
Basically what im asking is should i go XL 12 or Level 4 12"?
I dont wanna take up the whole trunk hence the 1 12" or id go 2 12's or 15's but heres a pic of the trunk.. minus the aftermarket floor liner.
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Level 4 on 2k.
even tho its rated at 1400 rms?
Level 4 on 2k.
They are underrated, if you are smart about it, and design a good box, it will take 2kw all day long. But you have to make sure you arent clipping causing a ton of extra heat.
Level 4 on 2k.
i was gonna go with a crescendo bc2000d or maybe a used dc 2k..
i wanna wire low so box rise doesnt kill me... where can i find wiring for the .7 coils? 1.4 coils?
For a single
Dual .7
parallel is .35 ohms
Series is 1.4 ohms
Dual 1.4
Parallel is .7 ohms
Series is 2.8 ohms.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
For a single
Dual .7
Series is 1.4 ohms
Dual 1.4
Parallel is .7 ohms
Series is 2.8 ohms.
can i get a level 4 with dual 1.4 coils? cuz on the site it says d1 oe d2 i misread and was reading the XL
